koni yellows
Old Dec 4, 2004 | 07:57 PM
808b18c1boosted's Avatar
Default koni yellows
I need some help with several things. I got the koni/ground control setup and was wondering what slot to put the retaining ring on 1,2 or 3rd and what difference it would make. also if i drop the snap ring down more will it allow me to preload the springs. The last question is where can i buy the spacers and bushing sleeve to accommodate the larger shaft. I bought the setup from a friends show car and i had to drill all of my stock spacers to make it work . Thanks for the help
Old Dec 5, 2004 | 07:01 AM
ice11honda's Avatar
Default Re: koni yellows (808b18c1boosted)
The firts ques I can answer which is put the retainig ring in the middle, best position imo whe I rocked that set-up. Not sure about the preload, or spacers, and for the bushing sleeve, are you referring to the one that fits inside the coilover sleeve? If so you can order from ground control
Old Dec 5, 2004 | 11:30 AM
sabotage7's Avatar
i just left mine in the middle and in the top....dont really need to mess w/that since you have coilovers and can adjust the height that way....that, and the snap ring looks like a pain in the *** anyways!
RHGSR01
Feb 2, 2010 11:01 AM
rEnZ94tEgGy
Suspension & Brakes
Apr 12, 2008 07:07 PM
nocturnal EG
Feb 2, 2006 10:57 PM
taytay333
May 29, 2002 07:49 PM
