o2 cx wireharness
Old Dec 5, 2004 | 10:19 PM
(Civic_Duty)'s Avatar
Default o2 cx wireharness
ok i know the 92 cx is wired for vtec. but what is the deal with the 4 wire o2 is the 92 cx prewired for the 4 wire o2
i need to know for the b18b swap i am doing...
i will be running a p28 /uberdata
Old Dec 6, 2004 | 02:30 PM
Default Re: o2 cx wireharness (tweakedcrx)
Old Dec 6, 2004 | 05:36 PM
Kataku2K3's Avatar
So long as it's a '92 (they're the only ones I know for sure always came with VTEC, etc.) it should be wired with everything. It's been a long time since I've played with the factory '92 CX wiring harness so I can't be sure. If you wanna double check it before you start the swap just check the pinouts for the oxygen sensor heater, if it's there then you're fine, if not then you'll need to add it in. I made a diagram a long time ago for the conversion so if you end up needing it let me know and I'll load it up.
Old Dec 11, 2004 | 09:52 AM
Default Re: o2 cx wireharness (Kataku2K3)
could u post it please
Old Dec 11, 2004 | 01:33 PM
Kataku2K3's Avatar
This should cover just about everything but if you have any questions let me know. -Adam
icucnme
Feb 12, 2004 10:24 AM
DEVIN22CBR
Apr 30, 2003 10:42 PM
