ARP rod bolts
Old Nov 29, 2004 | 11:39 PM
TURBL0W's Avatar
Default ARP rod bolts
Is it really necessary to have the rod bolt ends re-sized? Who is running arp rod bolts without resizing them? To replace rod bolts all I need to do is take out my oil pan unbolt the old rod and bolts and then put in the arp rod and bolts right? What do I torque them down to? What else do I need to do to take replace the rod bolts?
Old Nov 30, 2004 | 05:55 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: ARP rod bolts (lsvtec_power)
uh no. if you're using stock rods, then yes, you must have the rods resized. it would also be wise to install new bearings as well.
please do a search on this topic.
Old Nov 30, 2004 | 01:53 PM
TURBL0W's Avatar
What do you mean by stock rods? and what else is needed? where can i buy the bearings at?
Modified by lsvtec_power at 4:08 PM 12/1/2004
Old Dec 1, 2004 | 02:58 PM
TURBL0W's Avatar
bump, just want you guys to know I did searched and there are some people who actually didn't resize their rods and their motors are still running. I need more info before actually doing this.
Modified by lsvtec_power at 4:13 PM 12/1/2004
Old Dec 1, 2004 | 03:32 PM
backdraft's Avatar
Default Re: (lsvtec_power)
I used arp rod bolts and did no tre-size the rods. I was going to but the machine shop that I used to go to said just buy the correct size and you won't need to do anything. He said that re-sizing the holes would create a weak point where he re-sized the holes. So just get the ones for an Ls rod and you should be alright.
Old Dec 1, 2004 | 05:16 PM
TURBL0W's Avatar
Default Re: (backdraft)
So I just need to replace them? Everything can be done by myself right?
Old Dec 1, 2004 | 06:23 PM
mmuller's Avatar
Mad Scientist
yes you can do it by yourself, but you have to check to see if they egg shaped; you might get lucky and not have to resize, but you might not.
LSVtechnologytur...
Jul 14, 2008 07:39 AM
neyrod
Feb 16, 2005 11:05 AM
b16supertuner
Dec 15, 2003 05:21 AM
turbociv
Sep 8, 2003 05:41 AM
Drag R
Jun 14, 2003 07:54 AM
