my dyno sheet...
Old Nov 30, 2004 | 03:20 PM
vteczone's Avatar
Default my dyno result...
i just want confirmation of my dyno result..i want to confirm whether it is WHP n engine hp on the chart..and is my tq really read almost 169ft/lbs?
specs:toda c,ferrea valvetrains & valves.87.2mm stroke in b16a..CTR IM oversized TB 68.5mm.4-1header,PnP b16 head and haltech E6K engine management.any comments..may be
Old Nov 30, 2004 | 04:49 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: my dyno result... (vteczone)
Thats some nice WHP! (and TQ)
Old Nov 30, 2004 | 08:51 PM
vteczone's Avatar
thanks.. running stock 81mm bore ctr piston.
Old Nov 30, 2004 | 08:59 PM
FalkenSiR's Avatar
Default Re: (vteczone)
Damn those are some nice numbers!
What's your secret for that much torque from a b16 ?????
Old Nov 30, 2004 | 09:31 PM
mmuller's Avatar
Mad Scientist
what rods are you using?
Old Nov 30, 2004 | 09:33 PM
vteczone's Avatar
i dont have secret actually..never realise the Tq.i was a bit disappointed at first with the HP but some one pointed out my tq # then i started to think..thats why i posted it so someone can shed some light on this... b16a block with 87.2mm stroke with deckplate, ctr pistons and pr3 conrods..Pnp head flowbenched...
Old Nov 30, 2004 | 09:35 PM
Banned
I'd like to see your AFR...
Old Nov 30, 2004 | 11:16 PM
JDMotive's Avatar
I dont think it would be 169ftlbs on a dynojet.Mustve been the way that dyno was setup.I had a 89mm stroke b16a,85mm bore,15:1 compression etc..it made 230whp and only made 160ftlbs.Your HP numbers seem a little low for that setup,but still decent numbers.
Old Dec 1, 2004 | 01:04 AM
vteczone's Avatar
Default Re: (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">I'd like to see your AFR...</TD></TR></TABLE>
i'll try to source it..and will post it here.
Old Dec 1, 2004 | 06:28 AM
rapid_roy's Avatar
It's also a corrected graph, but not 100% sure as the RPM's are cut off. If the lines don't cross at 5252 then it's corrected.
Grab some numbers from the chart and plug them into this:
HP = Torque x RPM ÷ 5252
and see if it jives.
Old Dec 1, 2004 | 07:25 AM
vteczone's Avatar
graph isnt corrected..the reason i cut off the graph bcos the rpm isnt tally to what the actual RPM of the engine so people wont get confused. the guy at the dyno told me its bcos of the transmission mods i did which doesnt make sense to me..if u want i will post the whole uncut graph..
Old Dec 1, 2004 | 07:34 AM
vteczone's Avatar
Default Re: my dyno result... (rapid_roy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rapid_roy &raquo;</TD></TR><TR><TD CLASS="quote">It's also a corrected graph, but not 100% sure as the RPM's are cut off. If the lines don't cross at 5252 then it's corrected.
and see if it jives.</TD></TR></TABLE>
i dont have the chance to scan it yet but i did calculation base on your formula n fornula actually work!
with the rpm at approx 4950rpm X the torque is approx 160 and divide the 5252..i got the answer of 150.799 which is what actual shown on my graph.i will post them later..
volkdlr
12
Jul 8, 2005 09:08 PM
nsxmatt
40
Sep 8, 2003 01:08 AM
blu_si
Mar 8, 2003 04:58 PM
keebler65
Dec 2, 2002 08:42 PM
