wideband & narrowband o2 sensor
Old Dec 2, 2004 | 05:02 PM
ruthlesstyper's Avatar
Default wideband & narrowband o2 sensor
I am wondering what is the differences between narrowband and wideband o2 sensors. thanks in advance!
Old Dec 2, 2004 | 05:11 PM
vtekstorm's Avatar
Default Re: wideband & narrowband o2 sensor (ruthlesstyper)
narrow bands only read up to 1 volt and a wide band reads up to 5 volts. wide bands are much more accurate when tuning a car
Old Dec 2, 2004 | 05:39 PM
Default Re: wideband & narrowband o2 sensor (vtekstorm)
thanks !
Old Dec 2, 2004 | 07:02 PM
PrettyLude's Avatar
yeah, wide bands are pretty accurate
Old Dec 3, 2004 | 02:09 AM
sinister6's Avatar
But the cost? and compatability?
my o2 sensor is a little screwed was thinking of getting a wide band or stick with stock
Old Dec 3, 2004 | 04:24 AM
EE_Chris's Avatar
Default Re: (sinister6)
Widebands need a controller of some sort (the stock ECU on the HX and VX take care of this - aftermarket WB's have a seperate controller box).
Stock 4-wire O2's do not need this. You could put these in a bench vise and with a propane torch you can make it output a voltage.
If you tried that with a wideband, the only thing it would do is get hot.
4g4drb17
Jun 14, 2004 11:52 AM
opto_isolator
Mar 27, 2004 05:37 PM
birz
Jan 14, 2004 04:39 PM
NeXtLeVeL_TyPe_R
Mar 19, 2002 03:54 AM
fastestdriver
Jan 19, 2002 08:04 PM
