bleeding air out of radiator
Old Dec 3, 2004 | 05:19 PM
5genhatch's Avatar
Default bleeding air out of radiator
does anybody know how to bleed the air bubbles out of the radiator of a jdm itr motor? does it have a bleed screw?
if so can you provide pictures or say how i could locate it.
thanx
Old Dec 3, 2004 | 07:41 PM
eda6's Avatar
Default Re: bleeding air out of radiator (5genhatch)
<FONT COLOR="green">Follow the upper radiator hose until it meets the head. Look for a 12mm bolt with a hole in the center. Loosen the bolt and tighten once air is removed.
The other way to do this-Start the motor when cold and remove the radiator cap. Turn on your heater and set fan at max speed. Let the car reach operating temp and put the cap back on when bubbles stop coming out.
You'll get the same result either way.</FONT>
dlo102106
Sep 28, 2007 03:44 PM
GREENMOB$TER
Dec 3, 2006 07:52 PM
egg_baLLa
11
Mar 1, 2005 06:47 PM
pnltnc
Mar 30, 2004 06:30 PM
TenaciousC
Aug 22, 2002 02:11 PM
