GSR p72 ecu
Old Nov 29, 2004 | 10:25 PM
TURBL0W's Avatar
Default GSR p72 ecu
I have a p72 ecu on my ls/vtec and the rev limiter is in between 7k and 8k. Pass 7 under 8. Is the normall or what? Well anyway, I bought the car from someone that got it tuned already and the funny thing is on the dyno sheet, it cuts out after 8k. I will have to check the vtec controller and see how high the rev limiter is at. But the question is, if I get my ecu chipped will I have to get the car tuned again? if so is there anyway I can get away without tuning it again? Also for those who want to know why I want to rev higher than 8k is because the cams I have.
Old Nov 30, 2004 | 01:55 PM
TURBL0W's Avatar
ttt
Old Dec 1, 2004 | 02:58 PM
TURBL0W's Avatar
bump
Old Dec 1, 2004 | 03:19 PM
mattssi's Avatar
Why would you rev a ls/vtec pased 8k anyways. The bottom end wasn't designed to rev that high, and unless you have some modifications done, your looking at a spun rod bearing, or worse. I imagine that the rev limit was put there as insurance by someone who knew what they were doing.
Old Dec 1, 2004 | 05:14 PM
TURBL0W's Avatar
Default Re: (mattssi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattssi &raquo;</TD></TR><TR><TD CLASS="quote">Why would you rev a ls/vtec pased 8k anyways. The bottom end wasn't designed to rev that high, and unless you have some modifications done, your looking at a spun rod bearing, or worse. I imagine that the rev limit was put there as insurance by someone who knew what they were doing. </TD></TR></TABLE> read the first post. Cams make power past 8k, crower stage 3. Motor is ls/vtec with civic type r pistons, balenced polished/shot peened rods, balanced ls crank, crower valve train.
Old Dec 1, 2004 | 06:29 PM
mmuller's Avatar
Mad Scientist
Default Re: GSR p72 ecu (lsvtec_power)
if the car is already tuned and all you want to do is raise the rev limit with a chip you can and you dont have to re-tune
Old Dec 1, 2004 | 11:31 PM
TURBL0W's Avatar
Default Re: GSR p72 ecu (mmuller)
So what chip will I need to get?
Old Dec 12, 2004 | 08:54 PM
TURBL0W's Avatar
How come my rev limiter is before 8k? I have no CEL.
Old Dec 12, 2004 | 09:22 PM
notstock93's Avatar
Default Re: (lsvtec_power)
Your tach may simply be off a little bit. what year and market did your P72 come from?
I know auto B16 ECU's red-line lower than manual versions, I don't know if a auto option was given with the JDM GSR's. I doubt it, but its worth mentioning.
Aftermarket ignition?
Old Dec 13, 2004 | 06:24 PM
TURBL0W's Avatar
it's a 94 gsr computer. Ignition is MSD digital 6. Rev limiter is set at 9000 on it.
Old Dec 13, 2004 | 09:14 PM
notstock93's Avatar
Go back to stock for a day, see what happens.
Old Dec 13, 2004 | 09:46 PM
TURBL0W's Avatar
What do you mean go back to stock?
Old Dec 14, 2004 | 07:41 AM
notstock93's Avatar
I mean take out the digital ignition box and run the stock ignition. 90 percent of the time that's whats causing the problems concerning ignition.
severaltony
Mar 15, 2012 11:23 PM
ef-hatchcrap
Oct 23, 2007 03:26 PM
respectblades
Jan 19, 2005 07:14 AM
rev-speed
13
Feb 3, 2004 09:16 PM
Mr.DC2TurBo
Oct 5, 2003 09:20 PM
