Possible to re-use a 28 pin socket ?
Old May 28, 2011 | 12:11 AM
eppymoto69's Avatar
Default Possible to re-use a 28 pin socket ?
I have a p06 converted to vtec with a chip and socket with my tune saved on it , but this ecu has a bad circut (fuel pump relay) .. so i have another vigan po6 ecu that i can use but i want to know if i could transfer my socket and vtec software on to the virgan ecu ? Like is it possible to de-satuer the socket and etc from the ecu without meesing it up and sauter it into a different ecu ? And what to use for this ? Help on this please ! Save me some money !!!
Old May 28, 2011 | 03:06 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Possible to re-use a 28 pin socket ?
WTF is sauter? It's solder! What has happened to the education system?
If it can be soldered IN it can be taken out and reused. You should try Google to see how it's done.
Old May 28, 2011 | 09:22 AM
mikesrex's Avatar
if you are good at desoldering and soldering you will be able to do it. it is no easy task for the unexperienced to desolder the chip and socket. the caps, resistor and jumper aren't too hard.
Old May 28, 2011 | 12:54 PM
eppymoto69's Avatar
solder , whatever lol , and ok thanks.
Old May 29, 2011 | 10:54 AM
xile6's Avatar
yea you can reuse them if your good at soldering.But there like $2 at frys
Old Jun 1, 2011 | 06:25 AM
GettingOut's Avatar
I highly, highly doubt that you'll be able to de-solder that socket. I'm an electrical engineer who designs/builds PCBs all day and it'd be a challenge even for me. The sockets are only $0.50 usually. Try Fry's, or Radio Shack if you have to. And don't try using one of those gimmicky vacuum-pump de-solderers; you'll need some copper braid. But again, the copper braid will cost more than the ECU components... What you're talking about doesn't make much sense.
hood ride eg
Southern California
Aug 30, 2010 01:39 AM
jeck_bar2
Mar 11, 2009 09:12 AM
beatthisspeed69
Mar 12, 2008 04:52 PM
littlemracura
Aug 17, 2004 02:13 PM
auto moto
Aug 10, 2004 12:30 PM
