2JZ Solstice Build
Old Jun 23, 2011 | 10:11 PM
pantherqs's Avatar
Default 2JZ Solstice Build
Was told I should post this up here as well, so here ya go...
Got bored.. Yanked my LNF... Dropped thingy in...
Pretty sure it's the world first solstice 2jz swap.
ghetto leanin'
swapped these
rear sump clears the crossmember so well
then attached stuff
so big
then did a tranny
then used a forklift to put that...
...in here
like this
then tom ground some stuff
... stood up here and pointed at stuff
and then the 2jz was in
and the peasents rejoice
gone well..
pantherqs's Avatar
Default Re: 2JZ Solstice Build
Everything major bolted up, torqued down, and dropped in. Transmission transmission's. Driveshaft driveshaft's. Clutch clutches. Mount's mount. Thing's thing.
titan sent some stuff
bumper got mounted
tom mocked up the intake manifold...
...then welded a series of tubes together
and hi 4 inch downpipe
None of this would have been possible without the masterful fabrication of Tom at Ontario Mandrel.
Build Recap:
2JZGE
Borg Warner S372
AEM v2 EMS
Precision 1000cc injectors
Stock Aisin AR5 transmission mated to the jz via a 1JZ bellhousing.
Custom Spec Stage 5 Clutch
LS Coils
etc
going for 650-750 at the wheels conservatively on pumpgas... with plenty of headroom to go with racegas... should be fun!
Old Jun 23, 2011 | 10:36 PM
Lewy. Dee Ayy's Avatar
tittys
Old Jun 23, 2011 | 11:27 PM
spoolin94ls's Avatar
is the stock rearend goin to hold up to that much horsepower
Old Jun 29, 2011 | 05:03 AM
celicaxx's Avatar
2J's are like Ron Jeremy: they'll go in everything
Old Jun 30, 2011 | 07:47 AM
2TGEU's Avatar
looks good fellas! let me know how that AR5 holds up, been wanting to do that to my IS300.
Old Jul 1, 2011 | 08:55 PM
tundra2000's Avatar
wonder if i can put a 2jz in my civic
Old Jul 3, 2011 | 10:05 AM
Boosted_01 R's Avatar
Who you getting it tuned by? Have a datsun 280z with a 2JZ and running a AEM EMS v2 also.
Old Jul 3, 2011 | 03:13 PM
pantherqs's Avatar
we're tuning it... we put the v2 in... turns out the injector drivers were bad maybe... they were only pulsing the injector once.. then staying on the entire time.... it was getting statsync so i doubt it was a wiring issue... we traced everything... we put a ems form a 240 in, wired up a harness, and got the 2jz going on that and it fired right up...
Old Jul 3, 2011 | 04:52 PM
pantherqs's Avatar
http://www.youtube.com/watch?v=5dXYU4U4erg
also, it started yesterday.... rad and ic are in now...
Old Jul 4, 2011 | 12:25 PM
pantherqs's Avatar
http://www.youtube.com/watch?v=QnKdD68gu50
Old Jul 5, 2011 | 06:32 AM
jsgarage's Avatar
very impressive fab work. but a solstice? oh well
Old Jul 5, 2011 | 03:27 PM
MR.johnson's Avatar
very cool.
StuckInTexas
Mar 30, 2018 03:44 PM
inyoteef
Nov 7, 2006 07:41 PM
jdmcrx_echelon
Sep 30, 2006 10:02 PM
jbell
Jun 8, 2005 12:42 PM
WowOzYouRock
Mar 16, 2005 09:14 PM
