b16a pr3 ecu limp mode?????
Old Jun 30, 2011 | 03:41 PM
b16DooD's Avatar
Icon2 b16a pr3 ecu limp mode?????
bounces off around 3K cant figure out y????
please need the help
Old Jun 30, 2011 | 03:48 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: b16a pr3 ecu limp mode?????
Check timing, also you can jumper the service port and see what the mil codes are.
Old Jun 30, 2011 | 03:55 PM
b16DooD's Avatar
its in a ef check timing it was off wasnt it change map and iac checked the pin outs wired up all the sensors also idk was told ecu could be in limp mode????
Old Jun 30, 2011 | 05:34 PM
civickiller's Avatar
What did you say ???
Old Jun 30, 2011 | 06:08 PM
b16DooD's Avatar
i changed the iac and map
timing was off but fixed it
i was told the ecu was in limp mode
Old Jun 30, 2011 | 08:43 PM
Sounds like it is. Pull the codes
Old Jul 14, 2011 | 07:47 AM
b16DooD's Avatar
sooo update bounces off 3.5K even while driving
replaced dizzy, map, tps re timed it everything
didnt set the tps yet though but found out car needs a fuel pump could that be it??????
90integ
Jun 7, 2011 10:15 AM
sinaloa_ef
11
Apr 4, 2011 07:56 AM
Atech77
Feb 15, 2010 08:17 PM
89sih22a
Jun 11, 2005 10:35 AM
ELSpool
May 2, 2003 11:35 PM
