JDM B18C1 with white smoke at VTEC
Old Jun 7, 2011 | 05:59 PM
GilliesEK's Avatar
Default JDM B18C1 with white smoke at VTEC
Hi All
So with my recent C1 swap into my EK, I'm noticing white/greyish smoke out the exhaust when I hit VTEC...any ideas why? And is this normal?
Old Jun 8, 2011 | 07:07 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: JDM B18C1 with white smoke at VTEC
no..not normal for any car
need more info.
did you tune the car?
compression test?
losing oil/coolant?
new plugs?
Old Jun 9, 2011 | 02:18 AM
civickiller's Avatar
Doesn't smoke at all out of vtec?
I would do a leak down test, that would tell you if it's the head gasket or not
Old Jun 13, 2011 | 10:10 AM
GilliesEK's Avatar
need more info.
compression test?
losing oil/coolant?
new plugs?
Car is not tuned. ECU was chipped:launch control, redline at 8500,better MAP
Compression was perfect, 230 across
No loss of fluids that I can see
And new plugs were installed.
Possible idea: at VTEC the car runs richer, cause for smoke?
Old Jun 13, 2011 | 10:28 PM
Da91b18b's Avatar
need more info.
compression test?
losing oil/coolant?
new plugs?
(((((( i got a 91 ls and lately its been smokin reallly bad blowing out white smoke and i don't know what it could be. I'm not losing any coolant, But i am burning a little bit of oil.????))))))
Old Jun 14, 2011 | 10:28 AM
not white smoke.
White smoke = coolant
Blue smoke = oil
black smoke = rich
Possibly blue smoke? How much smoke? Harder to tell what color if smoking only little
Old Jun 14, 2011 | 10:44 AM
is there any oil at the bottom of your overflow tank?
Sounds like headgasket
any over heating?
You can do a leak down to see if any air bubbles are coming out of radiator
Old Jun 22, 2011 | 03:23 PM
Da91b18b's Avatar
Its Blowing Out White Smoke! Sometimes a lot of smoke and sometimes it doesn't even smoke, but i noticed something leaking, its two hoses that go under the intake manifold, its leaking green liquid which i think is coolant because it smells just like it. and no over heating what so ever
Old Jun 22, 2011 | 03:40 PM
Yup thats coolant. Check coolant level. Low coolant can result in a warped head and a blown hg .
But sounds like hg, u should get the head resuranced because it probably warped
93califerio
Nov 20, 2011 12:26 AM
jdmjoka
Feb 11, 2009 12:11 PM
vtec2190
Nov 5, 2008 01:27 AM
93daintegra
Jul 21, 2008 04:40 AM
00ITR725
May 13, 2003 06:28 AM
