oxygen sensor
Old Jun 20, 2011 | 05:31 AM
michaelsej1's Avatar
Icon2 oxygen sensor
is an o2 sensor for a sohc Honda the same as a b series o2 sensor? rywire sells an o2 sensor and says its for a d series and b series but other part manufacturers i look up the part number between the sohc and dohc dont match
Old Jun 20, 2011 | 06:04 AM
grumblemarc's Avatar
The Grumpiest
Default Re: oxygen sensor
Maybe you should be asking Rywire why their part numbers don't match up.
Old Jun 20, 2011 | 09:41 PM
hybridmiklo's Avatar
The year makes a difference (obd 0 , or obd 1 or obd2) and the plug for the vehicle. Nothing else.
Old Jun 20, 2011 | 09:58 PM
mibayaua's Avatar
Get it from autozone.
Old Jun 21, 2011 | 05:29 AM
autozone wants $115 and jhp has it for 65. i have a brand new one but it was for my sohc but still obd1 so ill just stick with that
Old Jun 24, 2011 | 11:20 AM
HAMOTORSPORTS's Avatar
OBD1 4 wire O2 sensors are all the same, with the difference only being the length of wire to the connector (and thus a different part number). Most universal 4 wire O2 sensors just use a longer length of wire so that it can fit more applications.
FYI do NOT buy the autozone "bosch" o2 junk. Get an NTK (made by NGK/OEM Honda) We have the universal 4 wire NTK for $79 http://www.hamotorsports.com/stntkoxse4wi.html
The bosch O2 is very slow in responding to air/fuel fluctuations while the NTK is fast responding which will help the ECU to make correct adjustments in closed loop.
Old Jun 26, 2011 | 06:06 AM
HondaPartsHero's Avatar
Technical Hero
I always use the Denso sensors and get them really cheap (usually 65 shipped) from Amazon.com. Like he said above don't use the Bosche sensors.
vtechjunkie
Sep 23, 2008 11:41 PM
eg:R
Apr 22, 2007 03:10 PM
astroxtc
Dec 13, 2006 12:57 PM
Se-rv-Tak
Nov 29, 2003 03:41 PM
