motor mount
Old Jul 23, 2005 | 12:22 PM
STN_Pat's Avatar
Default motor mount
When I hit the throttle "hard", it feels like the motor moves and is hesitate 1 sec before it revs.
I've added to all 3 torque mount ES poly insert....believe it or not it still does it.
What's up ?
Old Jul 23, 2005 | 05:19 PM
STN_Pat's Avatar
Default Re: motor mount (STN_Pat)
Old Jul 24, 2005 | 07:03 AM
STN_Pat's Avatar
I wish I could tell
Old Jul 24, 2005 | 01:57 PM
ben_eg6's Avatar
the only way to check your motor mounts if they are good or bad is pop up the hood, have some in step on the gas pedal, put it in 1st gear with parking brake is on and you watch it.
by the way, it sounds like your distributor is bad.
Old Jul 25, 2005 | 12:50 PM
STN_Pat's Avatar
Default Re: motor mount (Eg6B18C1)
1st gear = in front of it ? Right ! thanks for trying.
It's not the distributor. It's a translation problem, not a fire problem.
Old Jul 25, 2005 | 01:56 PM
JimBlake's Avatar
You can grab the valve cover & try to shake it, look for too much sloppy motion.
Or hold the main brake pedal (I wouldn't trust the handbrake) & brake-torque if it's automatic. If it's manual, you can heel/toe to do the same thing. Have someone do this while you stand alongside & watch for excessive movement of the engine.
But when you said 'hesitation' it really does sound like something else. ESPECIALLY with your poly inserts.
Championship
May 9, 2008 05:18 AM
dan200
Feb 25, 2008 10:30 PM
sablan02
Feb 6, 2007 11:48 PM
PH3593A
Oct 27, 2004 08:26 PM
Team 4R
Jan 12, 2004 08:54 PM
