Thermostat
Old Jul 17, 2005 | 06:36 PM
Fatty_1775's Avatar
Default Thermostat
How do you know if your thermostat has gone bad? ie there is hot air coming out of my vents when the setting is on cold, but the temp reads normal, but the air coming is out is kind of hot. Thanks.
Old Jul 17, 2005 | 08:05 PM
onepoint6i's Avatar
Default Re: Thermostat (Autobot_Killer)
your engine's not overheating= your thermostat is working
Old Jul 17, 2005 | 08:13 PM
FortunateFool.'s Avatar
Bad thermo wouldnt blow hot air. Bad Thermo can sometimes lower temps when your switch to heat and full blower on(Means its stuck open believe). Sounds like something else to me
Old Jul 17, 2005 | 09:19 PM
Fatty_1775's Avatar
Default Re: Thermostat (FortunateFool.)
What could cause the air to become hotter?
Old Jul 17, 2005 | 09:23 PM
HondaTechPro's Avatar
No, your thermostat is fine. Some people don't realize that a thermostat controls the MINIMUM temperture your engine... not the max. To prevent overheating the ECM or a thermo switch will turn on the cooling fan as needed. The cause for hot air could be anything from a stuck open hot water valve (located in the heater hose under the hood, with a cable going to it) or a broken blend door in the HVAC box, or maybe your AC doesn't work and it just seems hot.
Old Jul 18, 2005 | 07:23 PM
Fatty_1775's Avatar
Default Re: Thermostat (HondaTechPro)
i have no ac
jackhis
Jun 18, 2022 10:26 PM
maznkid
Oct 21, 2011 05:44 PM
crxricer66
Dec 10, 2007 04:41 AM
SpoolnByYou
34
Jul 6, 2006 04:42 PM
flood
Dec 5, 2005 06:21 PM
