Prelude CLUTCH Line Problems...!!! Please Read.
Old Jul 25, 2005 | 09:04 PM
Geeq's Avatar
Default Prelude CLUTCH Line Problems...!!! Please Read.
Hi,
Need input. My Factory Pressurized Cluth Line Was damaged in my engine Bay.
The Line Leading From the Clutch Master Cylinder to the Transmission.
Honda Part # 33649
#10 on list in this diagram http://www.hondaautomotivepart...INDER
It's a Long Story....But it's been replaced. Everything works fine but routing the new hose was a real pain. It is now rubbing in (4) Places. On (2) other pressurized lines, the firewall, and another area. I can hear rattling at certain RPMs and can see were it rubbing on the other hoses and will sooner or later cause a problem.
I was going to try and bend it a little to try and stop the rubbing. I might be able to.
BUT.....
I saw Goodridge lines and fitting and thought about using a Flexible Fose and fitting to replace the pre-bent stock hose.
http://www.goodridge.net/maincat2002/SECTION1.pdf
Can this be done???????? Will it work???????
I was thinking of custom making the line the same length and use zip ties and route it as a replacement. No rubbing and No problems.
Any Info Will Help.
prelude72569858
Sep 14, 2008 08:00 PM
lifeofbean
Jan 5, 2006 05:57 AM
s13_240sx_92
May 16, 2005 03:34 PM
youngkow
Jan 17, 2003 01:00 PM
