B16 block, gsr head how do you do it?
Old Jul 24, 2005 | 12:45 PM
NotPhilTran's Avatar
Default B16 block, gsr head how do you do it?
I have an obd 0 b16 block. I might be able go get a b18c head. how hard would it be to install?
Old Jul 24, 2005 | 10:27 PM
Default Re: B16 block, gsr head how do you do it? (NotPhilTran)
specifically would it bolt up to a b16 block using b16 arp head studs?
can i use a stock b16 hg?
can my obd 0 pr3 ecu with hondata control the IM or would i need a skunk2 GSR im?
thanks to anyone that can help me
my car is at the d yno broke right now!@!!
Old Jul 25, 2005 | 07:24 AM
f@sth@tch89's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NotPhilTran &raquo;</TD></TR><TR><TD CLASS="quote">specifically would it bolt up to a b16 block using b16 arp head studs?if u are going to use a b18c head on a b16...use gsr head studs or arp studs for a gsr.
can i use a stock b16 hg? NO use a GSR
can my obd 0 pr3 ecu with hondata control the IM or would i need a skunk2 GSR im?obd-0 ECU will work on a skunk2 IM...if u are going to use a stock GSR, u will have to take out the secondary butterflies because the obd-0 ECU doesnt open those.
my car is at the d yno broke right now!@!!</TD></TR></TABLE>
i had a similiar combo earlier this year. b16 block, GSR head..ctr cams and pistons...S2 manifold...amde 195 hp.
good luck!
Old Jul 25, 2005 | 08:30 AM
mmuller's Avatar
Mad Scientist
Default Re: B16 block, gsr head how do you do it? (f@sth@tch89)
You decide what head studs to use by the BLOCK not the HEAD.
you have a b16 block you use b16 head studs...
b16 and gsr hg's are the same..
the only way you can control iabs is either swap to obd1 and use a transformed p75 or p72.
If not you can just wire up a rpm activated switch for them
Old Jul 25, 2005 | 09:22 AM
Default Re: B16 block, gsr head how do you do it? (mmuller)
could i buy an aftermarket IM made for a GSR that elimnates the butterflys?
thanks for the answers.
Old Jul 25, 2005 | 09:24 AM
also i can remove the Stock butterflys from a stock gsr IM?
i already have a b16 headgasket, can anyone confirm that it will work with a gsr head?
anything else i need to take into consideration?
Old Jul 25, 2005 | 09:46 AM
mmuller's Avatar
Mad Scientist
i would think about leaving the secondaries working; they work good with the low displacement of the b16; it helps mid/low torque.
dont leave the butterflies open unless you want to loose power.
yes you could buy an aftermarket IM, but youll spend $ and loose power over the gsr IM with mild mods
dtenakoun
Feb 19, 2009 10:23 PM
spoonhatchblack
13
Sep 27, 2005 08:52 AM
k00lt1nt
Mar 9, 2005 06:48 PM
