apexi v-afc setup
Old Jul 21, 2005 | 02:55 AM
hondaboybt's Avatar
Default apexi v-afc setup
i hav just got a apexi v-afc2 controler, now once you hav wired it up and done initial setup are all the air and v-tec settings the same as before wiring it up, in other words is ok 2 fit it then hav it adjusted on rollin road later but till then would it just run as normal as long as settings not changed
Old Jul 21, 2005 | 06:46 AM
1995Civic's Avatar
yes, you can have it installed and it will still run with the same stock settings. vtec will still kick in at the stock rpm range until you adjust it.
Old Jul 23, 2005 | 07:29 AM
hondaboybt's Avatar
Default Re: apexi v-afc setup (hondaboybt)
is it still ok 2 drop the vtec point slight but still keep other settings as stock
Old Jul 23, 2005 | 09:36 AM
PrettyLude's Avatar
i wouldn't do it unless you know what your doing
dx2sicrx
Engine Management and Tuning
May 19, 2008 10:21 AM
ldanphanl
Mar 10, 2005 09:38 PM
gamakichi77
Sep 10, 2004 09:16 AM
OLM-02R
Apr 19, 2003 12:28 AM
BaddAzzTypeR
Sep 19, 2001 03:31 AM
