How and what do u have to do to replace cams?
Old Jul 22, 2005 | 08:11 PM
Black-Line's Avatar
Default How and what do u have to do to replace cams?
How and what do you need to do to upgrade a camshaft? I'm not going big, just stage 2. I was woundering if i could do it myself with the right tools?
Old Jul 22, 2005 | 08:26 PM
PrettyLude's Avatar
with the right tools you can do it, its basically a timing belt job, while you are at it, change the cam seal and check the condition of the crank seal and waterpump, and adjust your valves after that
Old Jul 22, 2005 | 08:51 PM
91civicDXdude's Avatar
dont forget about changing valve springs, retainers, and valve keepers
Old Jul 23, 2005 | 07:33 AM
DZNUTTS's Avatar
Default Re: (91civicDXdude)
will you need to do it on a stage 2 cam....
Old Jul 23, 2005 | 07:54 AM
PrettyLude's Avatar
generally on stage 2 cams, they recommmend you replace valve springs and retainers
Old Jul 23, 2005 | 09:05 AM
Black-Line's Avatar
they said on the web-sit that you dont need replace anything, is that true or not? and if it is, would i be better of with a stage 2 or 3, if i have to change everything any way?
Old Jul 23, 2005 | 09:47 AM
Finger Lickin' good's Avatar
Default Re: (Black-Line)
jesus, just cause its a bigger cam doesnt mean its what you want. Say a stage 4, you would end up loosing 10 hp in your daily driving rpm.
Save yur money, get a stage 1, its all you need/want in a daily driver. Power can be made else where and you keep the driveability.
Old Jul 23, 2005 | 10:12 AM
PrettyLude's Avatar
and what web site is this?
Old Jul 23, 2005 | 06:01 PM
Black-Line's Avatar
the crower web site
Old Jul 23, 2005 | 09:17 PM
generally, if the cam is mild (i.e. Type R, or stage 1 aftermarket) you dont need to change the valve train, just dont rev it much past stock rev limit, i'd say 8500 would be okay.
If you have a bigger set of cams, you need the upgraded valve train to handle the aggressive lift and to prevent spring binding, and most importantly, to handle the higher revs where you'll be making power.
I have personally seen 2 stock block b16s revving to 10,000, although not daily, but occasionally. I've also seen a kid with a b16a SiR1 chip his ECU, rev the engine to about 9800 with stock cams & valvetrain, and a retainer broke, dropped a valve into the cylinder, and completely destroyed the block and head. The block isnt the weak point, the valvetrain is.
If you want piece of mind, upgrade the valve train and have nothing to worry about. but if you're on a budget, a stage 1 or type r cam set should be fine with stock valvetrain.
Old Jul 24, 2005 | 09:01 AM
Black-Line's Avatar
thanks for the advice....i'll probably replace the valve train..it would be a great piece of mind.
Old Jul 24, 2005 | 09:24 AM
Black-Line's Avatar
does anybody know if there are any specifications or anything that i have to know when replacing these parts?
I wana do the swaps myself, i cant afford to take it to a full blown mechanic to do it, they charge too much.
gustavito1986
May 14, 2008 04:53 PM
TANGO28
Oct 2, 2007 05:41 AM
dominicanyo
Jun 27, 2007 10:38 AM
VTECth1s
Aug 27, 2006 06:53 AM
h22vt
Jan 26, 2006 03:15 PM
