ignition switch?
Old Jul 19, 2005 | 05:40 PM
squirrels's Avatar
Default ignition switch?
Does anyone know how to test an ignition switch on a crx? Is there a way to hot wire it 2 see if that is actually the problem? The car wont even turn over and the fuel pump wont kick on so could this be the ignition switch? Seached but couldnt find much. Thanks in advance.
Old Jul 19, 2005 | 05:51 PM
slomofo's Avatar
GDD Member
Ignition switch doesn't control the fuel pump.....although the main relay controls BOTH the starter and the fuel pump.
Old Jul 19, 2005 | 06:51 PM
PrettyLude's Avatar
Default Re: (slomofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo &raquo;</TD></TR><TR><TD CLASS="quote">Ignition switch doesn't control the fuel pump.....although the main relay controls BOTH the starter and the fuel pump.</TD></TR></TABLE>
Old Jul 20, 2005 | 01:01 AM
squirrels's Avatar
Default Re: ignition switch? (squirrels)
But how can you check it? Anyway to bypass it or test it?
Old Jul 20, 2005 | 11:20 AM
JimBlake's Avatar
I'm pretty sure the main relay has NOTHING to do with the starter.
The ignition switch is pretty simple. Helm book shows the 3 circuits & you can check continuity thru it with a multi-meter.
Old Jul 20, 2005 | 12:37 PM
slomofo's Avatar
GDD Member
Default Re: (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure the main relay has NOTHING to do with the starter.
I'm pretty sure you're mistaken there buddy.....eh...what do I know, i'm just a mechanic that deals with this crap on a daily basis, maybe you're right, maybe it is his ignition switch causing no cranking and NO FUEL.
WetCoastRacing
May 20, 2017 02:28 AM
andyvaj
Aug 15, 2012 09:44 AM
melloman
Feb 14, 2012 03:41 PM
Mr.Death
Audio / Security / Video
Jul 21, 2008 07:11 PM
MaukaRunner
Dec 9, 2003 06:09 PM
