over heating problem
Old Jul 18, 2005 | 05:04 PM
bobby hill's Avatar
Default over heating problem
I have a 1986 Honda Civic that water is shooting out of the radiator cap. Is it the thermostat or water pump
Old Jul 18, 2005 | 07:04 PM
Lewdin' Incognito's Avatar
Default Re: over heating problem (bobby hill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bobby hill &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1986 Honda Civic that water is shooting out of the radiator cap. Is it the thermostat or water pump</TD></TR></TABLE>
Lol, well that's not good! If it was a water pump problem then I would assume there wouldn't be any flow, the fact that it's pressurizing pretty much says that the water pump is at least working. It could just be your radiator cap, if you have one on there that is a lower psi rating than what you need or it is bad. I dunno, does "shooting out of the radiator cap" really mean that you have a fountain under your hood or is it just leaking?
Old Jul 18, 2005 | 07:19 PM
PrettyLude's Avatar
headgasket
Old Jul 18, 2005 | 09:06 PM
89hybrid's Avatar
I'd say head gasket or perhaps head.
Old Jul 19, 2005 | 01:11 PM
bobby hill's Avatar
Default Re: (PrettyLude)
if you have the cap on,the water comes out the sides of the cap
Old Jul 19, 2005 | 01:53 PM
Crazydave's Avatar
Default Re: (bobby hill)
Things to check,
How does you cap look ( you may want to start by considering replacing it.)
1.) Is your engine overheating before it starts to **** out by the cap?
2.) Is your fan turning on and turning off?
your fan should turn on when your engine warms up, once it cools off enough the fan turns off, when it heats up again, the fan turns on again.. an so on and so forth
then start checking fan switches, fan fuse/operation etc
carrollrucker
Aug 28, 2013 11:09 PM
accord2civic2prelude
Dec 10, 2009 09:19 PM
Null zahlen
19
Sep 14, 2009 02:10 PM
92civicx
Sep 18, 2007 07:08 AM
HiChanDC2R
Apr 2, 2006 07:32 PM
