Sputtering and Idle problem's.
Old Nov 18, 2005 | 09:06 AM
95eg6's Avatar
Default Sputtering and Idle problem's.
A couple of week's ago my car died on me at a redlight. I thought it was a distributor problem so I replaced the distributor. Timed it to 16 degree's and it still idles from 300 to 1200 back and fourth like a vacuum leak. After the car die's sometime's it won't start and after long period's of time it will start for a couple of second's then die. After I replaced the distributor the car was running but with a flucuating idle (drove it for about an hour). Then the next day I drove it the rpm's were bouncing around and it was sputtering. Other than doing a compression test does anybody else have any idea's? Thank's.
Modified by 95eg6 at 6:28 PM 11/22/2005
Old Nov 18, 2005 | 12:36 PM
95eg6's Avatar
Default Re: Sputtering and Idle problem's. (95eg6)
ttt
Old Nov 18, 2005 | 06:32 PM
95eg6's Avatar
bump
Old Nov 19, 2005 | 09:32 AM
Agent Zero's Avatar
I would also like to know. I am having the same problems.
I have a C5 block GSR head. Pretty much stock with bolt ons.
Old Nov 19, 2005 | 01:19 PM
95eg6's Avatar
Default Re: Sputtering and Idle problem's. (redsihatchback)
bump
Old Nov 21, 2005 | 08:50 PM
95eg6's Avatar
ttt
Old Nov 22, 2005 | 06:58 AM
95eg6's Avatar
bump
Old Nov 22, 2005 | 10:17 AM
Takumi Fujiwara's Avatar
well, the car dying problems sounds like a PGM-FI main relay problem...
Old Nov 22, 2005 | 01:53 PM
JDMCivicEF9's Avatar
Default Re: Sputtering and Idle problem's. (Takumi Fujiwara)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Takumi Fujiwara &raquo;</TD></TR><TR><TD CLASS="quote">well, the car dying problems sounds like a PGM-FI main relay problem...
</TD></TR></TABLE> Thats the ANSWER!!!
Old Nov 22, 2005 | 02:57 PM
Default Re: Sputtering and Idle problem's. (JDMCivicEF9)
When you say the RPMs are bouncing around, are you saying that the tach is bouncing around or the jerking/stuttering motion of your car correlates with the tach's movement?
Old Nov 23, 2005 | 06:23 PM
95eg6's Avatar
I tried another main relay but my car still die's after about 5 second's. I can smell fuel. When I try to give it gas it die's right away. Any other thought's?
Modified by 95eg6 at 9:47 AM 11/24/2005
Old Nov 23, 2005 | 08:21 PM
95eg6's Avatar
ttt
Old Nov 24, 2005 | 05:16 AM
project_K's Avatar
i had a problem like that on my motor. try the t.p.s. my was so bad that when you took off it would hit about 3g rpm then it was almost like i took my foot off the pedal. it would drop back down to about 1g rpm with pedal on the floor. when it idled it would go anywhere from 500 rpm to 1500 rpm. i took the tps off. car ran good but sluggish. so try that. if thats not it a guy told me that a map sensor would do that. but dont know how true that is.
Old Nov 24, 2005 | 07:19 AM
william72364's Avatar
fitv fast idle throttle valve . locate right under the throttle body take it off and open it up and screw the white cap down it probaly came unscrewed like mine did
Old Nov 24, 2005 | 08:23 AM
Keith Pierson's bitch's Avatar
check your IAC on the back of your intake manifold, shold have two coolent lines going ot it and a plug for the sensor.. take the two bolts out, and take it off clean it with some brake cleaner or intake mani cleaner, thne put it back on... if it still does it then your iac is prob bad try and borrow someones and see if it fixes it.
Old Nov 24, 2005 | 08:49 AM
95eg6's Avatar
Default Re: Sputtering and Idle problem's. (xxturbodreamsxx)
Alright thanks for the suggestion's I'll try them today.
Old Nov 24, 2005 | 06:19 PM
integra da's Avatar
i would replace fuel pump
Old Nov 25, 2005 | 07:24 AM
95eg6's Avatar
Default Re: Sputtering and Idle problem's. (tsointegra)
Well I havn't tried replacing the fuel pump yet. I had it idling for 5 minute's last night but the idle was flucuating and I couldn't time it. It kept going from 300-1200 again.
Old Nov 25, 2005 | 04:30 PM
did you clean the iac? the fuel pump isnt going ot cause it to idle like that.. if you cleaned it and it doesnt fix the problem borrow someones iac that does work and try it
Old Nov 26, 2005 | 04:23 PM
Haltom Hatch's Avatar
Are you throwing any codes? Even if it dies it should still throw a code into the memory of the ecu. Check it clear it out then get it to toss a code again that should get you going in some sort of direction.
Old Nov 26, 2005 | 05:25 PM
95eg6's Avatar
Default Re: (Haltom Hatch)
Yea I tried and didn't get any code's. Now I'm going by process of elimination. I can't figure it out. I still havnt tried another IAC, tomarow I will have the chance.
Old Nov 28, 2005 | 11:26 PM
95eg6's Avatar
Default Re: (95eg6)
The problem was the igniter. On the 95 gsr distributor's they have 2 small screws from the outside of the distributor that hold the igniter down but they were too long so the igniter was bouncing around.
Old Nov 29, 2005 | 07:12 AM
Default Re: (95eg6)
good job on figuring it out man, i've never heard of it having that causing a problem
Old Dec 1, 2005 | 05:47 PM
project_K's Avatar
Default Re: (95eg6)
good to know
Old Dec 11, 2005 | 07:43 PM
elgros's Avatar
Default Re: (xxturbodreamsxx)
The igniter bouncing around ? on the outside of the distributor ... sorry i don't get it
