IACV for B16
Old Nov 25, 2005 | 09:35 AM
ericl's Avatar
Default IACV for B16
Does anyone know if the bolt pattern for B16's IACV is the same as B18's? I tried to get a IACV off of ebay, the guy said it was from a D series but would fit a B16...and of course it didn't...Also anyone have a IACV for a b16??? I would have waited to post the WTB but I really need this soon...
Modified by ericl at 10:56 AM 11/25/2005
Modified by ericl at 11:15 AM 11/25/2005
Modified by ericl at 11:21 AM 11/25/2005
Old Nov 28, 2005 | 11:55 AM
ericl's Avatar
Default Re: IACV for B16 (ericl)
bump...
Old Nov 28, 2005 | 12:44 PM
JimBlake's Avatar
It's just as important to know the year. I think the IACV from a 1995 B18 won't fit a 1999 B18.
Old Nov 28, 2005 | 05:41 PM
ericl's Avatar
92-95 JDM B16A SiRII, if anyone has an IACV that will fit this and it works i'll take it!
Old Dec 1, 2005 | 09:24 AM
ericl's Avatar
I think I may have found some stuff...after talking to some people I think an IACV from a 91 Teg LS (B18A1) will fit as will one from a 92-95 Civic CX (D15B8)...The bolt patterns look the same, I've only seen the shorter spread bolt pattern and the wider spread...The 94+ GSRs have holes for both and I think they use the wider spread...lemme know what you guys think...
Old Dec 1, 2005 | 12:24 PM
JimBlake's Avatar
Default Re: (ericl)
I wonder if the division is OBD-1 vs. OBD-2? The 91, 92-95 you mention would all be OBD-1.
Even if the manifold is drilled, you still have to match which type your ECU is able to control. I think the control signals are different.
Try hondaparts247.com or someplace like that. Once you find a IACV from some particular model/year, see whether the part numbers match.
Old Dec 1, 2005 | 02:20 PM
ericl's Avatar
I know that you have to match OBDI and OBDII...but not all OBDI civic/teg IACV's are the same...there are two different bolt patterns and two different styles of IACV
Modified by ericl at 6:31 PM 12/1/2005
cheeksnme
Oct 15, 2010 09:03 PM
alexanderig
Mar 30, 2008 04:39 AM
keaps206
Jun 7, 2005 06:59 PM
DX Hybridizer
Mar 4, 2004 10:51 AM
Wes90civic
Jan 19, 2004 11:18 PM
