Lowering compression with a thicker head gasket
Old Nov 21, 2005 | 05:56 PM
rmcdaniels's Avatar
Default Lowering compression with a thicker head gasket
I want to lower my static CR, it's currently in the high 12's. Normally I wouldn't use a thicker head gasket to do it because of quench and side loading issues, but my CR is so high right now because my head was very heavily milled. I figure if I use a .080" gasket then I'll just be putting the quench back to OEM and I have a closed deck block, so the sides should be well supported. Any reason not to?
Old Nov 22, 2005 | 08:09 AM
nonPOINT's Avatar
Default Re: Lowering compression with a thicker head gasket (rmcdaniels)
people use 2 gaskets to lower compression sometimes, so I see no reason to not use one thick one.
Old Nov 22, 2005 | 08:27 AM
Kendall's Avatar
Just make sure you've got good head studs.
Old Nov 22, 2005 | 03:20 PM
rmcdaniels's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Just make sure you've got good head studs.</TD></TR></TABLE>
Yeah, been using ARP's for years.
Old Nov 23, 2005 | 11:45 AM
tgreaves's Avatar
Default Re: (rmcdaniels)
I used a .053 on mine to lower the compression down to 10:1 for boost.. Its a Cometic std gasket and so far it works fine.. Im also using ARP headstuds..
Blue94Accord
Oct 23, 2010 04:00 PM
Ivan_JDM_hatch
12
Jul 13, 2007 06:44 PM
99RedSi
12
Mar 10, 2005 10:34 AM
btrim23
Apr 27, 2004 01:08 PM
p1ccoloz
Apr 21, 2003 09:41 AM
