Starting a brand new motor!!!
Old Nov 23, 2005 | 06:03 PM
civicjdmb16a's Avatar
Default Starting a brand new motor!!!
Im almost done building a new engine and im nevous as **** when it comes time to start it. I heard horror stories about melting pistons and rings f-in up. Should i have my tuner start it in my gargage or on a dyno.........anyone
Old Nov 23, 2005 | 08:03 PM
B20luda's Avatar
Default Re: Starting a brand new motor!!! (civicjdmb16a)
this is what i do ...and i havent had any probs... remove plugs, disable fuel, prime engine, crank until u get pressure, ck oil level after pressure is built up, i ALWAYS use a stock ECU and injectors to start the engine and drive it around a bit, now depending on what your doing with the engine turbo NA bla bla...if your using bigger injectors with your built motor i would drive it to the tuner on the stock ECU and injectors and swap them out at the tuners place then have him do the rest, u dont want to over fuel / run way rich on a new engine or any engine for that matter u can damage the rings...oh ya CK your ignition timing ck for leaks make sure coolant is full etc...good luck...
Old Nov 23, 2005 | 11:49 PM
biotech0123's Avatar
Default Re: Starting a brand new motor!!! (B20luda)
nuff said
Old Nov 24, 2005 | 06:25 AM
JDM00SI's Avatar
Default Re: Starting a brand new motor!!! (biotech0123)
yeah have the tuner start it up etc....
people say if you burn a basemap your safe to drive it etc....
Do you want to risk the price of your engine or towing it to the shop?
Old Nov 24, 2005 | 07:08 AM
Default Re: Starting a brand new motor!!! (JDM00SI)
thanks for the help. should be a monster when its done. aiming for 600hp
Old Nov 24, 2005 | 07:10 AM
JDM00SI's Avatar
nice. you in a similar situation as i am in breaking in a motor. Earl from Laskey Racing has a good write up on breaking in an engine.
Old Nov 25, 2005 | 08:02 AM
cool got a link
krob
Engine Management and Tuning
May 12, 2014 05:52 PM
EG-SIXV-TEC
Dec 5, 2013 06:26 PM
redflaredcrx90
Mar 21, 2010 12:46 PM
Flexin5
Jun 5, 2007 02:50 PM
