compression rings or head gasket?
Old Nov 22, 2005 | 07:06 PM
efstile's Avatar
Default compression rings or head gasket?
i have a SiRII B16 with a t3t4 turbonetics setup. did a compression test and its reading, from 1 to 4, 200, 198, 180, 150. the car is puffing blue smoke when i get on it hard and occasionally plumes of white smoke appear. it hasnt overheated but it gets warmer than usual on warm days, like between 50-60. i ordered a 2mm headgasket and headstuds hoping to fix the problem and let me boost it some more. but im afraid its the rings. radiator fluid looks clean and i just did an oil change and it just looked real dirty, and i might be mistaken but it looked like it had dark green streaks as it drained. i am colorblind so who knows. thanks.
Old Nov 23, 2005 | 02:39 AM
Adi Radoncic's Avatar
On Fire!
Default Re: compression rings or head gasket? (efstile)
Was the car professionally tuned? Sounds like the headgasket or the rings/lands are broke. Do you have to refill the car with coolant often? Take the oil cap and the valve cover off and see if there is a milky looking substance on the underside of the cap and valve cover.. If there is your headgasket is smoked, if not your block is gona need a rebuild.
Old Nov 24, 2005 | 09:27 AM
efstile's Avatar
Default Re: compression rings or head gasket? (Adi Radoncic)
i put a little in every so often, coolant that is. and i burn a quart of oil every 750 miles or so. its tuned real rich. so i dont know what to do. what o ya think now.
JENNY_EG6
15
Jul 9, 2010 02:14 PM
ganjasnack
May 21, 2008 11:22 AM
wicked_b16eg
Dec 29, 2007 06:39 PM
red4dr92
Jun 16, 2007 12:52 PM
LostSolVTEC
Mar 8, 2006 04:58 PM
