Ball Joint Seperator
Old Nov 21, 2005 | 06:49 PM
LSEGHATCH's Avatar
Default Ball Joint Seperator
Are they universal? I have a Ebay gift certificate and figured I'd pick one up due to the fact that I'll be working on my suspension in the near future and I know I'll need one. Also any other specialty tools that come in hand? I can't think of any right now.
Old Nov 21, 2005 | 06:57 PM
Lacaci Motorsports's Avatar
Default Re: Ball Joint Seperator (LSEGHATCH)
the best way to separate a balljoint is with a sledgehammer or a good hammer hitting the spindle just above the balljoint. Separators break the boots and you end up hammering everything anyways. just make sure to thread the nut halfway to avoid hitting the threads.
Old Nov 22, 2005 | 06:56 PM
acy76's Avatar
Default Re: Ball Joint Seperator (lacaci)
Hitting the LCA with a large hammer (perpendicular to the ball joint axis) works well. Failing that, search around and find the post detailing the use of a Craftsman 1/2" drive ratchet handle - great trick.
Old Nov 23, 2005 | 06:05 AM
IN VTEC's Avatar
https://honda-tech.com/zerothread?id=887859
The only time you'll need a separator is when you're working on a lift or have to separate the upper ball joint.
I get by without a separator for the upper ball joint. I use the separator fork and replace the boot.
Another alternative is to get a job at a Honda or Acura dealership. Our's has a public-use tool for all of the mechanics to use as needed.
Old Nov 23, 2005 | 10:13 PM
EnzoSpeed's Avatar
Default Re: Ball Joint Seperator (acy76)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acy76 &raquo;</TD></TR><TR><TD CLASS="quote"> search around and find the post detailing the use of a Craftsman 1/2" drive ratchet handle - great trick.</TD></TR></TABLE>
I second that .
I'd never use any seperator tool, or even think about pounding on anything with a hammer. That's asking to rip a boot.
The ratchet trick is so easy. I really don't understand why everyone doesn't use it?
Old Nov 24, 2005 | 11:03 AM
Cory man's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acy76 &raquo;</TD></TR><TR><TD CLASS="quote">Hitting the LCA with a large hammer (perpendicular to the ball joint axis) works well. </TD></TR></TABLE>
This method has NEVER failed me and I work at the dealer. No need for a special tool, I just hammer the LCA below the balljt.
Old Nov 24, 2005 | 01:35 PM
EnzoSpeed's Avatar
Default Re: Ball Joint Seperator (Cory man)
Why beat on something with a hammer when you can do it just as efficiently without any force?
93sivtec
Jul 24, 2007 08:36 AM
chunky
Suspension & Brakes
Mar 24, 2007 09:35 AM
LX4CYL
16
Feb 13, 2005 03:12 PM
rasinhell
Feb 3, 2005 01:47 PM
f@sth@tch89
Mar 1, 2004 06:04 AM
