Which Dist. and wires?
Old Nov 27, 2005 | 10:30 AM
jfoster's Avatar
Default Which Dist. and wires?
Alright, so I have an LS block and B16 head that I plan to put together to replace the motor in my LS-T.
I need a Distributer for the B16 head, unless there is a way to use my LS one .... so will any dist. from a DOHC Vtec work? regardless of year or B16/GSR/ITR ???
Also, I noticed the part#s are different for Vtec and Non-Vtec plug wires ... why?? I guess I can't reuse the 10mm wires that I have on the LS now ???
Old Nov 27, 2005 | 10:44 AM
mmuller's Avatar
Mad Scientist
Default Re: Which Dist. and wires? (jfoster)
you can use your ls dizzy if you cut one of the legs off.
You can also use the non vtec plug wires
Old Nov 28, 2005 | 05:00 PM
jfoster's Avatar
Default Re: Which Dist. and wires? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">you can use your ls dizzy if you cut one of the legs off.
You can also use the non vtec plug wires</TD></TR></TABLE>
I would definatley like to reuse the parts I already have... is that mod of the LS dizzy common? Reliable?
Thanks
Old Nov 28, 2005 | 05:30 PM
mmuller's Avatar
Mad Scientist
its common and just as reliable as stock
Old Nov 29, 2005 | 10:47 PM
boost'd_crx's Avatar
cut off one leg of the dizzy. plugs right up, but might only be able to put on one bolt.
88 EF Hatch
Aug 28, 2009 10:10 AM
Azn Kenny
Aug 20, 2007 04:54 AM
HatchSpeeD
Nov 13, 2006 05:12 AM
deucedeuceEK
Apr 15, 2006 11:43 PM
Qwikrex
Mar 15, 2003 08:06 AM
