D15B non vtec questions
Old Nov 27, 2005 | 10:08 AM
Ahknodd's Avatar
Default D15B non vtec questions
Hey,
I've got a D15B non vtec in a 91 Civic Hatch and my question is does anyone know the specs on this motor? I put a 91 Civic Si MPFI swap on it and the motor runs good, but I'm just wondering how similar this motor is compared to a d16a6. Are there differences in the heads? In the cams? I had a D16A6 in the car with I/H/E on it with the Si MPFI of course and the car was strong and ran 15.7's, but now with the same mods including the Si MPFI the car is weak. I know my stroke it down, but is that where I'm getting most of my power loss? The car is strong in the mid range and then torqueless in the top end. Plus the car sounds a lot louder, but it's the same intake and everything.
Remember this is a non vtec D15B (just d15b). I think it's the EDM D15B that was carbed. So I've heard it was rated at 100 Hp and 12.4 torque in kgm (what is that in ft lbs. ?). Does anyone know any differences compared to the D16A6 please let me know.
thanks for anything you've got.
Later, AHKNODD
Old Nov 28, 2005 | 02:45 PM
Ahknodd's Avatar
Default Re: D15B non vtec questions (Ahknodd)
Need some help, Please!
Old Nov 28, 2005 | 03:29 PM
projectTeG's Avatar
i believe that the a6 had a lil more agressive cam.
Old Nov 28, 2005 | 03:51 PM
Ahknodd's Avatar
Default Re: (projectTeG)
do you know if that is the major difference between the motors, well besides the displacement?
Thanks for the help.
Ahknodd
Old Nov 28, 2005 | 03:56 PM
projectTeG's Avatar
Default Re: (Ahknodd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ahknodd &raquo;</TD></TR><TR><TD CLASS="quote">do you know if that is the major difference between the motors, well besides the displacement?
Ahknodd</TD></TR></TABLE>
if your talking about the crx si engine the only difference is the cam and the displacement.
Old Nov 28, 2005 | 04:06 PM
Ahknodd's Avatar
Hey thanks.
So basically if I just drop in an A6 cam then the heads are basically the same, right?
Later, ahknodd
Old Nov 28, 2005 | 04:12 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ahknodd &raquo;</TD></TR><TR><TD CLASS="quote">Hey thanks.
Later, ahknodd</TD></TR></TABLE>
youll need a adjustable cam gear or possibly the a6 gear also. because i believe the cam will be a few degrees off
Old Nov 30, 2005 | 02:16 PM
Ahknodd's Avatar
Please anyone have anymore info for me?
I'm also wondering if all PM3 heads are the same as far as design, flow, valve size, etc. I know the cams in them may be different, but is everything else the same? My Head says PM3-12, I think the D16A6 has PM3-6, so do the numbers after the PM3 mean a different cam?
Old Dec 1, 2005 | 02:13 PM
Ahknodd's Avatar
Ej1Shayne
Sep 11, 2014 04:57 PM
Stray
Mar 30, 2007 09:33 PM
BanginNmy4door
Feb 11, 2006 09:44 PM
civicracer1993
Mar 22, 2004 04:59 PM
1hotvtec
16
Jun 21, 2003 11:10 PM
