obd2 to obd1 conversion question and more
Old Oct 7, 2006 | 06:02 PM
error's Avatar
Default obd2 to obd1 conversion question and more
i have a 96 hatch with a 98 b18b
id like to run a conversion harness and some dsm 450's with an obd1 ls ecu/chrome.
question is do i need to change my distributor? and what generation dsm's should i run? the 1st gen blue tops or 2nd gen? does it matter? what would i need to make the 450's compliant with my system? thanks.
Old Oct 7, 2006 | 08:50 PM
mtber's Avatar
Default Re: obd2 to obd1 conversion question and more (error)
You can run a obd1 or obd2 distributor on an obd1 ecu.
To run dsm injectors which are low impedance, you will need to run a resistor box.
Do a search for more info.
Concerning running an aftermarket or larger then stock injector, you will need to run an obd1 injector clip or an rc injector clip etc.
Search is your friend
Old Oct 7, 2006 | 08:54 PM
error's Avatar
Default Re: obd2 to obd1 conversion question and more (mtber)
thanks
98BBSiCxs
Jul 20, 2010 12:53 PM
rogue3221
Nov 23, 2004 11:36 AM
90Zcrx
Nov 19, 2002 11:26 PM
