Has this ever happened to anyone? please help
Old Oct 10, 2006 | 05:11 AM
jc2801's Avatar
Default Has this ever happened to anyone? please help
Hey everyone well last night i was driving in my 94 eg hatch (gsr swap) and a prelude H22 pulls next to me at a red light and the light turns green so we went ahead and slammed on the gas....My car redlined at 7 RPM's so I was like wtf so I shifted to 2nd gear and redlined again at 7 RPM's so I shifted to third hoping it wouldn't do the and same thing...I still got like a car and half on the prelude but my car usually redlines at 9200 RPM...I have a skunk 2 P28 ECU OBD-1 converted....and usually my vtec kicks in at 5200 RPMs and yesterday it was kicking in at 4500 RPM'S...Just 2 days ago I changed my cluster, I had a jdm cluster and now have a US automatic cluster w/ tach, could this be the problem?? cause the only other thing i changed was my valve cover and i dont think that effected anything....I also unplugged the wires from the ecu and plugged them back in to see if anything would change but i got the same results...Please let me know if this has happened to anyone and if so what did you do to fix it or if anyone knows what is wrong with my car...thanks
Old Oct 10, 2006 | 08:09 AM
Relic1's Avatar
you're new cluster's tach is off. Or you're old cluster's tach was off....
Old Oct 10, 2006 | 08:23 AM
jc2801's Avatar
Default Re: (Relic1)
I thought that could be the problem so I am going to exahnge it today and see if i get the same result....Because I dont know why it would make my vtec kick in earlier and redline sooner....and i previously had a US cluster and it was for a manual car off a civic ex before my JDM one and vtec kicked in at 5200 rpm and redlined at 9200 rpms....IDK but im going to try putting the jdm cluster back hopefully that solves it..thanks
Old Oct 10, 2006 | 11:17 AM
Relic1's Avatar
what is the chip setup for? that is what sets everything.
the cluster is simply displaying what it sees.
BTW, clusters can be calibrated but it's not easy to do.
Old Oct 10, 2006 | 11:38 AM
jc2801's Avatar
It is a skunk 2 p28 ecu obd 1 converted and it is set up for vtec to kick in at 5200 RPM's and redline at 9200 RPM's, and it has always been like that untill I installed that new cluster and changed my valve cover....really wierd and thanks for all the help
Modified by jc2801 at 12:51 PM 10/10/2006
Old Oct 16, 2006 | 08:58 AM
jc2801's Avatar
Default Re: (jc2801)
well i finally had the chance to change my cluster back to the jdm one...and it actually redlines at 9200 RPM's ...thanks for all the help...just posting this in case this happpens to someone else...really wierd but hey i'm nmot going to complian about it as long as it works fine.
JaayDeeEmm
Dec 9, 2012 10:47 AM
The-obd0-one
May 5, 2010 04:36 PM
Mfoehrkolb
Aug 23, 2007 07:16 PM
fishieman
Jul 14, 2007 08:42 PM
Methane2k2
Sep 6, 2004 11:38 AM
