would this hurt a motor
Old Oct 6, 2006 | 08:04 AM
MikeSarr_GSR's Avatar
Default would this hurt a motor
hey guys, ive had my gsr up on stands for a couple months. took it apart and
just got too busy at work anyhow, I pulled the tranny out of it and its been
sitting there. the engine has since shifted and last night for the first time I
actually noticed that the engine was hanging from the mount and resting
with the crank pulley against the frame. Its been sitting like that for a while
and I noticed last night that it might not be good for it. I propped it up from
the floor and got it off the framerail. should this be cause for concern?
the CP was sitting flush against the frame, the mount above was the only
mount securing the motor. thanks for your input
Old Oct 6, 2006 | 08:22 AM
hybridej7's Avatar
Default Re: would this hurt a motor (MikeSarr_GSR)
id put some jack stands underneath the motor to help hold it up.....
Old Oct 6, 2006 | 09:40 AM
Default Re: would this hurt a motor (hybridej7)
no worries, thats the right idea. will do, I have it propped up right now
but I will make something more substantial. hope nothing hurt the motor,
but we will see.
Old Oct 6, 2006 | 01:29 PM
d16dcoe45's Avatar
that is funny you mention that. I am actually going through something similar right now. When I was removing my old build that cracked a sleeve (my intentions are to take everything out of that motor and put into another block) the crank pulley got wedged in the bay as I was lifting the motor out--I was thinking I may have bent the crank snout--but from measuring the snout is fine no runout. Apparently it takes alot to bend a crankshaft.
Old Oct 9, 2006 | 02:21 PM
blinx9900's Avatar
should be fine, the guy i bought my motor from said he launched so hard the valve cover hit the hood and the crank pulley hit the frame rail... motor still runs strong... granted he only had it running on 3 mounts
Old Oct 10, 2006 | 08:41 PM
Default Re: would this hurt a motor (cusco9900)
cool guys, thanks for the ideas. I am sure everything is fine
kixcrx
Sep 23, 2007 02:30 PM
importdude2000
Jul 17, 2004 07:53 AM
01PYITR
Jun 30, 2002 02:58 PM
