any differnce between a p30 and itr head?
Old Oct 9, 2006 | 11:44 AM
the.hamburglar's Avatar
Default any differnce between a p30 and itr head?
what the differnence in the head itself? i mean other than cams and valves and springs. is the itr ported more?
Old Oct 9, 2006 | 12:16 PM
inspyral's Avatar
The ITR head is basically just a factory-ported P30 head with different cams and dual valvesprings on the intake side. That's why a P30 head on a GSR block is called a "poor man's Type R".
Old Oct 9, 2006 | 12:39 PM
Default Re: (inspyral)
what about a itr head on a gsr block?
Old Oct 9, 2006 | 01:34 PM
blinx9900's Avatar
Default Re: (the.hamburglar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar &raquo;</TD></TR><TR><TD CLASS="quote">what the differnence in the head itself? i mean other than cams and valves and springs. is the itr ported more?</TD></TR></TABLE>
flat dual valve springs on intake and standard (round coil) dual valve springs on exhaust to be exact...
Old Oct 9, 2006 | 01:36 PM
blinx9900's Avatar
Default Re: (cusco9900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">The ITR head is basically just a factory-ported P30 head with different cams and dual valvesprings on the intake side. That's why a P30 head on a GSR block is called a "poor man's Type R".</TD></TR></TABLE>
still a poor mans type r cause you dont have the high compression pistons with the moly coating. lite weight rods etc...
NA JDM GSR
Mar 1, 2005 04:11 PM
TyPe-R6
Jan 5, 2005 06:43 PM
MGITR
Apr 28, 2003 12:39 PM
memphiss13
Apr 8, 2002 12:02 AM
are_sicks
Jan 4, 2002 12:38 PM
