flywheel bolt!!!
Old Oct 3, 2006 | 07:00 PM
jdm206's Avatar
Default flywheel bolt!!!
ok here is the problem that im having. Oh yeah i forgot to mentation that the motor is out of the car. I need to take off the flywheel and when i try to loosen the bolts the whole crank just move. I need to find a way to take it off. help a guy out.
Old Oct 3, 2006 | 07:02 PM
vg7z's Avatar
get a tire iron 19mm, or a 19mm beraker bar and attach it to the crank bolt. Then just loosen the flywheel bolts and the tire iron/breaker bar will hit the ground and hold it for you
Old Oct 3, 2006 | 07:43 PM
jdm206's Avatar
Default Re: (vg7z)
kool thats for the help. I appreciate it.
Old Oct 4, 2006 | 03:08 PM
boostedblkef's Avatar
Default Re: (jdm206)
impact gun also works
Old Oct 4, 2006 | 08:00 PM
gsrious's Avatar
i see nothing so hard. just get a big enought flat head screw driver and lodge it in the flywheel teeth and the webing of the engine. as one is doing that, another person can loosen the bolts.
^^worked for me all the time everytime.
Old Oct 5, 2006 | 01:56 PM
dutchman5's Avatar
Default Re: (gsrious)
best way is use the phillip screwdriver that fit a small hole inside flywheel... it work charm !
Old Oct 5, 2006 | 04:42 PM
NathanielH's Avatar
Default Re: (dutchman5)
or buy a ring gear holder for 8 bucks from autozone
eh2_Trav
Transmission & Drivetrain
Nov 4, 2016 08:47 AM
jasonfierst
Oct 18, 2009 01:04 PM
.Thomas
Jan 16, 2007 10:45 PM
integraautox
Dec 24, 2003 06:14 PM
jondancer
10
Apr 18, 2003 07:19 AM
