compression check....manually?
Old Oct 5, 2006 | 11:21 AM
kinkyintegra's Avatar
Default compression check....manually?
I have a d16 sitting in my driveway that i am selling but i want to run a compression check....how do people jump their starters? i know the wire for the starter isnt long enough to reach the engine...so either i jump it or my question is: can i just crank the pulley with a wrench....would i get accurate numbers?
Old Oct 5, 2006 | 11:46 AM
ykracing's Avatar
Default Re: compression check....manually? (kinkyintegra)
no you cant do it that way... find a friend or neighbor to come turn the key for you...
Old Oct 5, 2006 | 11:56 AM
turn the key? the engine is outside the car...so im asking how do people jump the engine for a compression check when it is outside the car...
Old Oct 5, 2006 | 12:22 PM
d16dcoe45's Avatar
Default Re: (kinkyintegra)
I have done it that way to check a motor before. It was an sr20det. Its not very accurate and you will get much lower numbers--but if it ends up a least over 100 and they are all near each other it should be ok. Its no substitute for a real compression test though. Just turn the crank pulley as fast as you can. You will get some numbers.
Old Oct 11, 2006 | 04:47 AM
ykracing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kinkyintegra &raquo;</TD></TR><TR><TD CLASS="quote">turn the key? the engine is outside the car...so im asking how do people jump the engine for a compression check when it is outside the car...</TD></TR></TABLE>
you dont need to jump it, you crank it with the key... I guess I dont understand the problem...
Old Oct 11, 2006 | 05:09 AM
mmuller's Avatar
Mad Scientist
Default Re: (ykracing)
hook up the starter and give it 12 v
DropSide
Apr 18, 2007 06:22 PM
92BlackSi
17
Apr 10, 2005 07:30 PM
Spence
16
Mar 5, 2005 06:13 PM
streetlegal gocart
Feb 15, 2005 08:12 PM
projektCRX
Apr 22, 2004 12:20 PM
