Bearing removal?
Old Oct 13, 2006 | 03:00 PM
93h22a1vtec's Avatar
Default Bearing removal?
Ok so im rebuilding my h22 transmision and I cannot seem to get the 2 bearings out that sit in the housing that hold the main and countershafts. Are they sappose to just slide out, or is there a trick to it?
Old Oct 13, 2006 | 04:33 PM
dpaton's Avatar
Default Re: Bearing removal? (93h22a1vtec)
Go to AutoZone or Pep Boys or someplace that loans tools and borrow a pilot bearing puller and the slide hammer that goes with it. They'll be out 2 minutes after you get home.
Plan on replacing the bearings after this though. Pulling them this way is hard on the races and can distort the bearings just enough to make them fail early in a spectacular fashion.
Old Oct 13, 2006 | 05:19 PM
Default Re: Bearing removal? (dpaton)
thank you
Old Oct 13, 2006 | 08:01 PM
integ401's Avatar
heat it up and slide it out
Old Oct 15, 2006 | 07:19 AM
dpaton's Avatar
Default Re: Bearing removal? (integ401)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integ401 &raquo;</TD></TR><TR><TD CLASS="quote">heat it up and slide it out </TD></TR></TABLE>
Fire will mess up the bearings even worse.
Bearing puller FTW.
Hellahflush
Mar 27, 2015 05:15 PM
rextasy
May 14, 2007 10:19 AM
marcussmith26
Jan 28, 2006 01:45 PM
John
Jul 5, 2002 08:52 AM
