B series tranny question
Old Oct 11, 2006 | 09:43 AM
Vtec mini's Avatar
Default B series tranny question
I have a 72 mini cooper that I am going to put and ls vtec conversion in. I need a hydro tranny and I wanted to know if I can use any b-series tranny.
I have a b18a block with a early b16 head running with a pr3 ecu. So can I use a 99 b18c hydro tranny with this ecu and have all of the electrical work properly? i.e. VSS and any other sensor that the ecu needs from the tranny?
If not can someone recommend a hydro tranny that will work with my setup using that ecu.
Old Oct 11, 2006 | 11:52 AM
Danny_EJ's Avatar
Correct. The b18c will be fine.
You can use any B series hydraulic tranny
GSR, ITR, CTR, LS, GS, B16...........94-01
Old Oct 11, 2006 | 01:29 PM
Bense's Avatar
you're going to fly through those gears with you're 10" rims!
Old Oct 12, 2006 | 12:45 PM
Jarfal's Avatar
Default Re: B series tranny question (Vtec mini)
go for S4C usualy comes on B16A2 Si,Sir
Old Oct 12, 2006 | 04:14 PM
SE3Pimp's Avatar
Default Re: B series tranny question (Jarfal)
yea, fricken vtec mini conversions are badass . just get a tune after if you mix and match ecu's from the motor
Magick211
May 11, 2011 10:42 PM
cu_jarrett
Apr 24, 2004 11:43 AM
hb_racer
Aug 20, 2003 10:50 AM
DaNish
Oct 8, 2002 06:05 PM
