IACV question?
Old Oct 7, 2006 | 08:53 PM
Kevin B's Avatar
Default IACV question?
With the IACV unplugged (closed), should there be vacuum on the port inside the throttle body?
Old Oct 8, 2006 | 02:30 PM
Kevin B's Avatar
Default Re: IACV question? (Kevin B)
Anybody?? I get vacuum at the port for the IACV when it is unplugged, when I'm trying to set the idle. Idle won't go to 450, even with the idle screw all the way closed. It will only go to 450 if I plug the port for the IACV with my finger.
Old Oct 8, 2006 | 02:37 PM
clayne's Avatar
http://www.team-integra.net/fo...52266
Old Oct 8, 2006 | 06:39 PM
Kevin B's Avatar
Default Re: IACV question? (clayne)
I think mine is bad, just want to make sure. I have cleaned it several times, like in that post. The valve is not sealing properly and letting air by, either the sealing surface being dirty, missing a o-ring or something else.
Old Oct 8, 2006 | 07:38 PM
clayne's Avatar
2 or 3 wire IACV?
Apply 12V battery to terminals, if it actuates - it's not bad.
Old Oct 8, 2006 | 10:03 PM
Kevin B's Avatar
2-wire. It actuates when I apply 12V.
Old Oct 8, 2006 | 10:25 PM
clayne's Avatar
Then the IACV is working just fine. That's all it does is accept a PWM 12V signal to regulate open/close.
Unless the actual IACV ring/gasket is bad, I'd continue checking other things.
Old Oct 8, 2006 | 10:33 PM
Kevin B's Avatar
I think that the seal/gasket is bad in the IACV and letting air by when it is closed (unplugged). I am trying to find out if when it is closed is there supposed to be vacuum on the port.
Old Oct 8, 2006 | 11:46 PM
clayne's Avatar
Try blowing through the IACV with it disconnected. This will verify if it is default open or default closed. I wouldn't be surprised if it's default open - as a failure case still allows the car to idle.
Old Oct 9, 2006 | 04:25 PM
Kevin B's Avatar
When I had it off of the manifold and it was disconnected it is closed (0V) and open when I applied 12V.
Old Oct 22, 2006 | 09:01 PM
88hondacrx's Avatar
So is there suppose to be vacumn when the iacv is unplugged?
90Rexx
Jun 29, 2008 09:35 PM
90Rexx
Jun 28, 2008 06:26 PM
sik_sol
May 25, 2006 01:56 PM
eK9aT10pSi
Oct 1, 2005 05:55 PM
