question about Koni yellows.
Old Sep 26, 2002 | 11:15 PM
Civicboy's Avatar
Default question about Koni yellows.
I know that Koni Yellows have an adjustable spring perch. I was wondering how much more lowering you can get if the perch is put at the bottom. Thanks
Old Sep 27, 2002 | 04:41 AM
PSU-TEG's Avatar
Default Re: question about Koni yellows. (Civicboy)
Depends on whether you be the yellows with 3 or 5 perches. But I'd somewhere between 3/4" an 1 1/2" depending which ones you buy.
But this is just an estimated guess. I have yellows with 3 perches, and just left them on the original perch... I think there was about 3/4 difference in the perches.
Old Sep 27, 2002 | 05:02 AM
BROOD's Avatar
Here are some pics of the KONI yellows to add some visual (yes these are H&R cup struts, they are KONI yellows) The Nuespeed version KONI's have additional grooves in the strut bodies. I don't have a set of those handy to compare against.
Rears (three groove settings) 3/4" spacing between grooves
Fronts 1 1/8" spacing between grooves
[Modified by SLPR, 9:51 AM 9/29/2002]
Old Sep 27, 2002 | 05:17 AM
Civicboy's Avatar
Default Re: question about Koni yellows. (SLPR)
is that actual size, looks like a lot. Thanks any measurements would help to
Old Sep 27, 2002 | 05:35 AM
BROOD's Avatar
I'll have a look tonight, I can't recall the measurements off the top of my head.
Old Sep 27, 2002 | 01:14 PM
performula's Avatar
Usually 5mm increments.
I have a question...my front yellows only have two slots on the front for perches. Sound right?
Old Sep 27, 2002 | 02:07 PM
reefer_bob's Avatar
Default Re: question about Koni yellows. (performula)
My Neuspeed/Koni Yellows had 5 settings, all were 1/4" increments.
Old Sep 27, 2002 | 02:14 PM
performula's Avatar
I have five in the rear, but only two in front.
Neuspeed were more expensive. If I have to, I'll just buy Neuspeeds later on for the front.
Old Sep 27, 2002 | 06:47 PM
Civicboy's Avatar
Default Re: question about Koni yellows. (reefer_bob)
where did you buy them from? thanks
Old Sep 28, 2002 | 05:09 AM
performula's Avatar
http://www.neuspeed.com has them.
Old Sep 28, 2002 | 02:10 PM
Civicboy's Avatar
thanks
Vantage
Honda Civic (2001 - 2005)
Mar 19, 2007 05:39 AM
Rpizzle
Apr 4, 2005 09:34 PM
crooked muffler
Jun 10, 2003 07:46 PM
taytay333
Mar 26, 2002 03:54 PM
Quest
Nov 30, 2001 10:25 PM
