how to remove eagle rod bolts
Old Sep 28, 2002 | 06:20 PM
vtec69's Avatar
Default how to remove eagle rod bolts
ok, i had the machine shop put on the piston rings and eagle rods together. now i've come to a problem. the bolts the hold the rods together are some weird looking nuts. i wanted to know if anyone knows exactly what tool i need to remove the bolts so i can put them in the crank. here is a picture so you can see what i mean.
Old Sep 28, 2002 | 06:57 PM
Chiovnidca's Avatar
Default Re: how to remove eagle rod bolts (vtec69)
Those are 10mm 12 point aren't they?
Old Sep 28, 2002 | 07:42 PM
TREVER's Avatar
Default Re: how to remove eagle rod bolts (Chiovnidca)
no
Old Sep 28, 2002 | 10:27 PM
miller's Avatar
Default Re: how to remove eagle rod bolts (TREVER)
they should be 10mm 12 points , i thought that is what eagle uses.
Old Sep 29, 2002 | 04:59 AM
Chiovnidca's Avatar
no
Well what are they then?
Old Sep 29, 2002 | 05:20 AM
FORCED FED TEG's Avatar
New User
I think its a 12 point 3/8. I went to 4 different stores till I found one that fit.
Old Sep 29, 2002 | 01:15 PM
vtec69's Avatar
Default Re: how to remove eagle rod bolts (FORCED FED TEG)
i got it to work. thanks for everyones help. and for your information a 12pt 10mm socket worked perfectly.
Old Sep 29, 2002 | 04:39 PM
earl's Avatar
A 10mm 12 point socket will work on Eagle Rods but the proper socket to use is a 3/8 12 point.
SanadaSand207
May 29, 2018 05:54 AM
SLIM NOTHING
Jun 6, 2011 10:38 AM
BlueSi2k
Apr 23, 2003 10:50 AM
vtec69
Sep 28, 2002 08:10 PM
vtec69
Sep 28, 2002 07:27 PM
