Piston to Valve Clearance Issues....
Old Sep 26, 2002 | 12:25 PM
Ink00's Avatar
Default Piston to Valve Clearance Issues....
If I milled my B18C5 Head 40 thousands and put a slimmer head gasket in would I run into clearance issues when using the Toda Spec B's?
Old Sep 26, 2002 | 01:52 PM
94gsr's Avatar
Default Re: Piston to Valve Clearance Issues.... (Ink00)
I'm not sure about clearance issues, but you're likely to have issues with the timing belt tensioner not being able to pick up all the slack. Even if you only get rid of one layer of the head gasket, that'll give you a total of about .050 off the distance between the cam gears & crank. That's pushing it.
Old Sep 26, 2002 | 04:00 PM
ViZ's Avatar
ViZ
Default Re: Piston to Valve Clearance Issues.... (94gsr)
i recommend claying the motor whenever you question clearnence, you have to take your time and do it right otherwise you can throw your money away..
here is a good how-to that shows what i mean
http://www.c-speedracing.com/howto/claymotor/clay.html
Old Sep 26, 2002 | 08:16 PM
ITR#132's Avatar
what bottom end?
Old Sep 26, 2002 | 10:45 PM
Ink00's Avatar
Default Re: Piston to Valve Clearance Issues.... (ITR#132)
I am running with a stock B18C5 bottom end.... I was planning on using the TODA Timming belt as well, if I can get a hold of one. I heard it was more reliable under higher RPM's.
VPR-01CTR
Feb 15, 2007 03:29 PM
AWDxBOOST
Nov 2, 2004 03:42 PM
Toda
Feb 26, 2003 03:17 PM
EK Ferio
Feb 10, 2003 02:46 PM
Mad Cow Disease
Nov 12, 2002 12:41 PM
