NEED a pic of Engine Coolant Sensor
Old Sep 26, 2002 | 06:58 PM
See Are X's Avatar
Default NEED a pic of Engine Coolant Sensor
Can someone please give me a pic of where/what it is? Or could someone explain to me where/what it is? What it actually does...
Old Sep 26, 2002 | 07:36 PM
tinkerbell's Avatar
Default Re: NEED a pic of Engine Coolant Sensor (See Are X)
it is under the distributor. and has a locking plug.
it tells the ECU how hot the coolant is.
the temprature sensor (smaller sensor) tells the temp gauge in your dash how hot hte engine is. and has a non-clicking plug. it is also under the distributor to the right of hte ECT sensor.
t..
Old Sep 27, 2002 | 08:12 AM
See Are X's Avatar
Default Re: NEED a pic of Engine Coolant Sensor (tinkerbell)
aight thanks...you know how many wires the ECT sensor has? and which wires go where?
Old Sep 27, 2002 | 11:24 AM
salbaje's Avatar
2 wires
Old Sep 27, 2002 | 12:46 PM
Quik Chris's Avatar
Default Re: NEED a pic of Engine Coolant Sensor (salbaje)
Don't forget about the one tapped into the block into the water jacket.
Old Sep 28, 2002 | 10:21 AM
See Are X's Avatar
Default Re: NEED a pic of Engine Coolant Sensor (Midori Shinkansen)
does anyone know where exactly these 2 wires go from the ECT sensor???
Old Sep 28, 2002 | 02:43 PM
Quik Chris's Avatar
To the wiring harness, then to the ECU.
Old Sep 29, 2002 | 10:14 AM
See Are X's Avatar
ok, which wire goes to the ECU? and where does the other wire go???
Old Sep 29, 2002 | 04:38 PM
See Are X's Avatar
ttt
Old Sep 29, 2002 | 04:42 PM
tinkerbell's Avatar
ok, lets actually work out what you are asking.
there are THREE engine coolant sensors.
1. controls hte radiator fan - it is the biggest, has 2 pins nad is usually on hte block or thermostat housing;
2. controls hte temprature gauge - it is smallest, has one pin and is usually on hte head;
3. controls nothing - it tells the ECU what hte temprature of the coolant is, and is usually on hte head.
which one are you asking about??????
(to be honest the ONLY sensor that can be refered to as the ECT sensor is no. 3)
t..
Old Sep 29, 2002 | 05:08 PM
See Are X's Avatar
its number 3...the one under the dist.
Old Sep 29, 2002 | 05:10 PM
tinkerbell's Avatar
what is wrong with it? are you getting a code?
what is the problem?
t..
Old Sep 29, 2002 | 05:20 PM
See Are X's Avatar
yes, im getting a code 6(ECT Sensor)...I know the sensor is fine, and I want to wire it up directly to the ECU. Now i know one wire goes to the ECU, I need to know which wire that is, and where the other wire goes to.
Old Sep 29, 2002 | 05:29 PM
tinkerbell's Avatar
the other wire goes to the ECU of course.
this is the earth (must be at ECU).
( the ECT is wired directly to the ECU, you should be able to check hte "continuity" of this connection with a multi-meter)
what ECU are you running?
t..
Old Oct 1, 2002 | 03:03 PM
See Are X's Avatar
I just wanted to straighten this out and ask my question again...this is what I need to know...
...I know there is 2 wires that go to the ECT Sensor plug, I need to know which individual wire goes where? I understand one wire goes to the ECU(which one is that?) and I dont know where the other wire goes...btw its a 90 LS ECU...
Old Oct 1, 2002 | 03:10 PM
tinkerbell's Avatar
t..
t..
Old Oct 1, 2002 | 03:19 PM
See Are X's Avatar
...ok...I just looked at the plug, theres a green/white wire, and a red/white wire...
Where does the green/white wire go???
Where does the red/white wire go???
Yes, I know one of these goes to the ECU...but which one??????
Old Oct 1, 2002 | 03:20 PM
tinkerbell's Avatar
both
t..
Old Oct 1, 2002 | 03:28 PM
See Are X's Avatar
both? really? Do you know what the wire locations are on the ECU, for both wires?
Old Oct 1, 2002 | 03:32 PM
tinkerbell's Avatar
no, because i dont know what the exact ECU you have is?!!?
on a PR3 ECU (JDM B16A) it is:
red/white = C6
green/white = C12
does this help?
see here anyways - http://www.geocities.com/b16aprelude/hondaengines.html
t..
Old Oct 1, 2002 | 03:45 PM
See Are X's Avatar
THANKS!!!! thats exactly what I was looking for...haha
Old Oct 1, 2002 | 03:47 PM
tinkerbell's Avatar
no problem, you just had to ask!
tinkerbell knows best!! (most times anyways)
t..
710dabber
Nov 5, 2015 12:36 PM
davecc95
Mar 30, 2015 05:16 PM
jemo1
Jun 5, 2013 05:55 PM
carpenterkyle
Nov 3, 2012 07:45 PM
davidluko
Nov 19, 2006 08:27 AM
