Wheel Spacers?
Old Sep 28, 2002 | 06:38 PM
EKFerioHawaii's Avatar
Default Wheel Spacers?
Hey, any of you guys use wheel spacers on your cars? If so, how thick? Different lug nuts? Extended studs?
I also, know that you must press in longer studs to be "safe". On the other hand, I've seen my friends use 25mm on S13s and S14s using stock studs and lug nuts.
Any opinions and comments about this would be helpful.
Old Sep 28, 2002 | 07:08 PM
Tweakmeister's Avatar
Default Re: Wheel Spacers? (EKFerioHawaii)
you'll probably need to have longer studs pressed in.
the H&R spacers are the one's I'm guessing you're talking about...the size will vary on what type of wheels you have (that need to clear the brakes/etc).
Old Sep 29, 2002 | 01:48 AM
AJ PwR's Avatar
If you run 5mm stock studs are long enough but anything thicker , replacing studs is recommended.
Old Oct 2, 2002 | 01:43 PM
Default Re: Wheel Spacers? (AJ PwR)
Thanks, dood....
Old Oct 2, 2002 | 01:44 PM
Default Re: Wheel Spacers? (Tweakmeister)
Yeah I was looking at the H&R spacers. Well, thanks alot dood
Old Oct 2, 2002 | 02:08 PM
no problem dude
EJ2B16
Nov 25, 2011 09:05 AM
ricehead
Nov 18, 2009 05:41 PM
KING PIN
Apr 24, 2008 06:26 PM
Midori Green
15
Jan 1, 2008 10:39 PM
thk
Mar 1, 2004 01:04 PM
