fastbrake rotor replacement
Old Sep 29, 2002 | 05:35 PM
crx(gator)'s Avatar
Default fastbrake rotor replacement
i heard that the replacement rotors for the 11'' civic upgrade comes from a vw corrado g60...can anyone tell me if this is so?
Old Sep 29, 2002 | 06:59 PM
Francois's Avatar
Default Re: fastbrake rotor replacement (crxgator)
yes.
But,you should have ask Brian....
Old Sep 30, 2002 | 05:46 AM
CheezeFrog's Avatar
Default Re: fastbrake rotor replacement (Francois)
Yes, it's from a G60 Corrado. I did ask Brian a while back and he confirmed. Buy it off the shelf and bolt it on. No modifications required.
Old Sep 30, 2002 | 07:32 AM
emr88's Avatar
Default Re: fastbrake rotor replacement (CheezeFrog)
I just posted this question in the Integra forum after doing a search on fastbrakes. Will this same VW Corrado rotor fit the Integra (94-01) without modifications?
Old Sep 30, 2002 | 07:41 AM
Jaker's Avatar
Default Re: fastbrake rotor replacement (emr88)
The rotors will fit, but then your stock calipers will not. You will need a caliper relocation bracket, as the Corrado rotors are 11.2" and your Integra rotors are 10.3".
Old Sep 30, 2002 | 08:22 AM
emr88's Avatar
Default Re: fastbrake rotor replacement (Jaker)
I thought the idea was to use ITR or Accord caliper with the larger 11" rotor?
Old Sep 30, 2002 | 08:47 AM
MikeSarr_GSR's Avatar
my buddy did it that way with his and his brakes are very good. much more agressive than the stock setup
Old Sep 30, 2002 | 08:51 AM
owen_the_soyboy's Avatar
1) you use that ITR setup on a civic or integra that already has 10.x front brakes... just using ITR calipers, rotors and a hub ring from Fastbrakes. (this setup rocks!)
2) for other (econo) models that have teeny front brakes, these have smaller hubs/knuckles and therefore BRian at Fastbrakes uses the Corrado rotrs and a relocation bracket to use the stock teeny calipers.
hialeahzbg
Suspension & Brakes
37
Aug 10, 2010 04:09 PM
tempsohc
Jul 20, 2009 03:11 AM
kess
29
Jun 16, 2009 09:58 AM
willimo
Nov 11, 2007 09:33 AM
fastbrakes
Aug 27, 2001 11:19 AM
