b18c1 wiring HELP!!!
Old Apr 5, 2003 | 02:48 PM
dose's Avatar
Default b18c1 wiring HELP!!!
i put a b18c1 in a 97 ls and it has a kenji chipped p28 and obd 2 to 1 harness,i dont kno much about wiring and was wondering what wires i need to run that aint there and where they go
Old Apr 5, 2003 | 04:50 PM
dose's Avatar
Default Re: b18c1 wiring HELP!!! (dose)
up
Old Apr 5, 2003 | 05:10 PM
AzG35's Avatar
The ECU is plug and play, you aren't going to be able to use your secondary butterflies with that ECU. You can do 2 things, one, the cheapest way, is disconnect the vaccum line to the butterflies and plug it, this will keep them open all the time but you will lose some low end power. Two, is buy a Skunk2 manifold, this will get rid of all of that stuff.
Old Apr 5, 2003 | 05:28 PM
dose's Avatar
i got a chipped p28 which doesnt read secondaries and i kno i need to hook up some wires but im not sure exactly which ones,i do kno i need to hook up vtec
Old Apr 5, 2003 | 08:23 PM
salbaje's Avatar
yes just hook up both vtec oilpressure and solenoid. that p28 doesnt look for knock also rite??
Old Apr 6, 2003 | 08:25 AM
dose's Avatar
Default Re: b18c1 wiring HELP!!! (salbaje)
no it doesnt read knock sensor anyone kno which color wires for the vtec oil and selonoid or pinouts on ecu
nfn15037
Sep 12, 2001 05:16 AM
