leaking tranny and CEL 43 for a b20 crx
Setup: b20 turbo w/ls tranny, obd0 pr4 ecu, b16a fpr in a CRX.
What should I check for a code 43? I already replaced the fuel filter and 02 sensor. What else could it be?
Also the ls tranny leaks around the passenger side axle. I replaced the oil seal twice. It held up for about 2 days then started to leak again. There is an unusual amount play where the axle goes into the tranny. I can move the inner joint up and down quite a bit. What could be the problem there?
Thanks.
Thanks.
Re: leaking tranny and CEL 43 for a b20 crx (Brad)
Did you get that cover thing thats @ the bottom? Its like a brush guard or something, but it goes inbetween the tranny and engine. What axles did you use? Did you remove the dust seal?
up cause if someone else knows post, btw what is code 43
Blaze
Blaze
Re: leaking tranny and CEL 43 for a b20 crx (Blaze45)
Yes I used a b16a cover. I used 90-93 Integra axles and I removed the dust seals. I had the same axles and intermediate shaft when the car had a b16a w\ s1 tranny and there was no leaks then.
Code 43 is fuel supply system-defective or malfunctioning fuel supply system.
thanks,
Brad
thanks,
Brad
ungcobob
07-30-2006 06:19 PM
