swap overheating
Old Apr 6, 2003 | 05:42 PM
Seye's Avatar
Default swap overheating
i have a b18b in a eg hatch, now that it is getting warmer outside i have noticed that when i am at idel my temp rises a lot. when driving the gauge is at about 3/8 of the way up. then when i am at idel it goes up to about 3/4. i dont have any mods to the colling swstem, is this normal????shuld i upgrade, or would a vented hood help? thanks
Old Apr 6, 2003 | 05:52 PM
yaya's Avatar
Default Re: swap overheating (sixsk8)
i would check your water pump
have you flushed your coolant latley?
do you have coolant ?
thermostat bad?
dont think "upgrade" until you've looked for a problem
Old Apr 6, 2003 | 05:55 PM
Seye's Avatar
Default Re: swap overheating (yaya)
Flushing tomorrow, getting new pump in a week when i change timing belt.
Old Apr 6, 2003 | 07:01 PM
intekragsr's Avatar
might want to check all the lines. Bleed the system again, test the thermostat, and make sure you fans are kicking on. Also may want to try a compression test to see if your headgasket is ok.
Old Apr 6, 2003 | 07:07 PM
splitime's Avatar
If you havent upgraded your radiator, that might be something to consider. A common one is replacing your single core( im assuming you kept the stock rad) and replacing it with a dual core.
Old Apr 7, 2003 | 02:38 AM
B18C2_sedan's Avatar
I had the same problem. I swap to a del sol vtec dual core one.
Chris404
Mar 21, 2013 04:25 PM
90teg94accord
Oct 17, 2009 10:30 PM
Doylerules4588
11
Jul 3, 2008 08:01 PM
Mohsin
Apr 27, 2005 08:01 AM
civic dx
Apr 8, 2003 09:51 AM
