Wiring GSR IM
ok ive got the three VTEC wires run. now i need to wire up the intake manifold. what color is the EVAP Purge Solenoid wire and where is it located? also, what color is the IAB Solenoid wire, and where is that located? TIA
NM. i found my answer on PG3. this forum r0x0rZ
[Modified by Vic Nyce, 7:09 AM 4/5/2003]
Evap is not necessary, I usually repin/switch A20 wire to A17, this way its much simpler.
Knock Sensor Red/Blue D3
Evap Purge Power Yellow/Black 12V power
Evap Purge Solenoid Red A20
Secondary Intake Solenoid Pink/Blue A17
