Water In Cylinders
Old Apr 6, 2003 | 10:29 AM
Diegolude's Avatar
Default Water In Cylinders
I was washing the engine and Water got into the Cylinders.
I cleaned out all the Cylinders. Took out the Water.
My Coil Wire was very oxydized. And Something is causing my Engine to Stutter when Revving when Driving.
My Dad says that the water left in the Engine will just evaporate if I run the engine.
Anyone Else have suggestions?
Or is it most likely the Coil Wire?
Old Apr 6, 2003 | 10:53 AM
altoid's Avatar
Default Re: Water In Cylinders (Diegolude)
did you spray some wd40 or put some oil on the cylinder walls to lube them back up? you could check your compression to make sure the rings didn't get ripped to shreds by rust that could have formed on the cylinder walls
Old Apr 6, 2003 | 01:00 PM
Perfectionist's Avatar
The cylinders? Or do you mean spark plug wells? The water will eventually evaporate with the heat from the engine.
Old Apr 6, 2003 | 02:02 PM
Diegolude's Avatar
Default Re: Water In Cylinders (Perfectionist)
Thank You, I left the engine running for about 1hr. Smoke starting coming out from under my Exhaust. about 2 feet away from the Cat.
I dunno if its just me, but the Exhaust sounds louder now.
Hrmmmm maybe Im tweaking but i think it made my Exhaust sound better.
Well the prob is solved. I am going to put some Electro-grease on all the wires.
Whew... Theres a huge Prelude meet 4/20 .
Old Apr 6, 2003 | 03:19 PM
icelarry27's Avatar
4/20? lol...have fun.
NullPointer
11
Sep 10, 2020 08:59 AM
hookedonponics
Apr 30, 2009 12:04 PM
EJ6SON
Dec 31, 2004 01:20 AM
SkylineGTR
Feb 5, 2004 04:45 PM
