.how hard is it to replace valve guide seals??
Don't you have to heat up the head and chill the valve seals to get them in, similar to installing piston and rod wrist pins?
Valve seals can be removed and installed with the head on the car. It requires compressed air, a rail type spring compressor, valve stem seal remover, and installer. Dealers do it this way all the time. If you try it without the right tools, it's very difficult. Or, you can pull the head.
Plenty of info in the archives..... but you can't search them right now.
Valve guides are an entirely different story.
Tom
[Modified by real9999, 10:03 PM 4/6/2003]
Tom
80 dolla crx hf
Sep 8, 2014 01:28 PM
