estimate for repairs?
Old Apr 5, 2003 | 01:55 PM
littledan's Avatar
Default estimate for repairs?
Hey everybody...
I am buying a used 1995 prelude SRV(i am in Canada). I have a preliminary inspection that the seller has faxed me. Here is a list of needed repairs:
1. Outer CV boot has crack... not sure which side.
2. Transmission Shift Seal Leaks.
3. Steering wheel off center.
4. Missing spare tire and jack.
The notes on the inspection say "oil leak on R/axle seal area ... shifted seals first... "
The compression is 175 across all cylinders. I will be taking the car in for another inspection before I buy. Can anyone ballpark how much the repairs would cost? Also.. why would the steering wheel be off center?.. Alignment?...
Thanks for all your help guys.
Dan
P.S. Not sure if this is right forum so mods can move if necessary.
Old Apr 5, 2003 | 02:17 PM
VTECorona's Avatar
Default Re: estimate for repairs? (littledan)
As far as the steering wheel thing, an alignment can fix that.. Figure around 100 or so bucks.
Old Apr 5, 2003 | 02:56 PM
fathergoose's Avatar
Default Re: estimate for repairs? (97RedTegGSR)
the seal job isn't very expensive, 30$ worth of parts, 1h30 of labor max, if youre slighly experienced, you can even do it yourself
Old Apr 5, 2003 | 02:57 PM
Default Re: estimate for repairs? (fathergoose)
you can easily find the spare and jack in a scrapyard for real cheap
Old Apr 5, 2003 | 03:04 PM
littledan's Avatar
thanks for the info so far...
would an alignment fix the steering wheel for sure or is there another reason that it could be off center??
Old Apr 5, 2003 | 04:03 PM
altoid's Avatar
bent control arm...happens when you hit something really hard, like a curb.
bigtimegambler
17
Dec 12, 2015 04:16 PM
Spaceballsthelunchbox
May 30, 2013 05:45 PM
Gunmetal Grey
May 5, 2008 08:15 PM
vti444
Jun 16, 2007 02:36 PM
cohenr
Aug 26, 2002 06:52 PM
